Error core Error while running background job
Hello! Enroll persistent errors in the. Can anyone met such.
This happened when changing AJAX to cron
Crontab -u www-data -e
  • / 15 * * * * php -f /var/www/owncloud/cron.php
Users receive an electronic message every 20-30 minutes indicating that the following events have occurred. The text is constantly repeated
"Hello, Svetlana Kopets,
You received this email because the following events occurred: http: //x.x.x.x//owncloud/
  • Anastasia Bazarevskaya shared with you English - December 14, 2016, 17:56:51
  • Aleksey Rai shared with you Plan a schedule for entering new equipment.xlsx - December 17, 2016, 21:23:45 "
Error while running background job (class: OCA\Activity\BackgroundJob\EmailNotification, arguments: ): {“Exception”:“Swift_TransportException”,“Message”:“Expected response code 250 but got code "551", with message "551 200104616 message sending quota exceeded, try later\r\n"”,“Code”:0,“Trace”:“#0 /var/www/html/owncloud/3rdparty/swiftmailer/swiftmailer/lib/classes/Swift/Transport/AbstractSmtpTransport.php(281): Swift_Transport_AbstractSmtpTransport->_assertResponseCode(‘551 200104616 m…’, Array)\n#1 /var/www/html/owncloud/3rdparty/swiftmailer/swiftmailer/lib/classes/Swift/Transport/EsmtpTransport.php(243): Swift_Transport_AbstractSmtpTransport->executeCommand(‘\r\n.\r\n’, Array, Array)\n#2 /var/www/html/owncloud/3rdparty/swiftmailer/swiftmailer/lib/classes/Swift/Transport/AbstractSmtpTransport.php(333): Swift_Transport_EsmtpTransport->executeCommand(‘\r\n.\r\n’, Array)\n#3 /var/www/html/owncloud/3rdparty/swiftmailer/swiftmailer/lib/classes/Swift/Transport/AbstractSmtpTransport.php(428): Swift_Transport_AbstractSmtpTransport->_streamMessage(Object(Swift_Message))\n#4 /var/www/html/owncloud/3rdparty/swiftmailer/swiftmailer/lib/classes/Swift/Transport/AbstractSmtpTransport.php(444): Swift_Transport_AbstractSmtpTransport->_doMailTransaction(Object(Swift_Message), ‘turovcloud@turo…’, Array, Array)\n#5 /var/www/html/owncloud/3rdparty/swiftmailer/swiftmailer/lib/classes/Swift/Transport/AbstractSmtpTransport.php(176): Swift_Transport_AbstractSmtpTransport->_sendTo(Object(Swift_Message), ‘turovcloud@turo…’, Array, Array)\n#6 /var/www/html/owncloud/lib/private/mail/mailer.php(105): Swift_Transport_AbstractSmtpTransport->send(Object(Swift_Message), Array)\n#7 /var/www/html/owncloud/apps/activity/lib/mailqueuehandler.php(264): OC\Mail\Mailer->send(Object(OC\Mail\Message))\n#8 /var/www/html/owncloud/apps/activity/lib/backgroundjob/emailnotification.php(134): OCA\Activity\MailQueueHandler->sendEmailToUser(‘4E281FF3-49DA-4…’, ‘bua@turovmilk.b…’, ‘ru’, ‘Asia/Baghdad’, 1496210605)\n#9 /var/www/html/owncloud/apps/activity/lib/backgroundjob/emailnotification.php(94): OCA\Activity\BackgroundJob\EmailNotification->runStep(500, 1496210605)\n#10 /var/www/html/owncloud/lib/private/backgroundjob/job.php(52): OCA\Activity\BackgroundJob\EmailNotification->run(NULL)\n#11 /var/www/html/owncloud/lib/private/backgroundjob/timedjob.php(53): OC\BackgroundJob\Job->execute(Object(OC\BackgroundJob\JobList), Object(OC\Log))\n#12 /var/www/html/owncloud/cron.php(145): OC\BackgroundJob\TimedJob->execute(Object(OC\BackgroundJob\JobList), Object(OC\Log))\n#13 {main}”,“File”:“/var/www/html/owncloud/3rdparty/swiftmailer/swiftmailer/lib/classes/Swift/Transport/AbstractSmtpTransport.php”,“Line”:383}
“user_ldap” 0.8.0
Operating system: Ubuntu Server 15.10
Web server:Apache/2.4.12
Database:mariaDB 10.0.25
PHP version:PHP 5.6.11
ownCloud version (see ownCloud admin page): ownCloud 9.0.9 (stable)
Special configuration (external storage - nas, external authentication- ldap, reverse proxy - no, server-side-encryption-no):
Probably just the queue of messages which got stuck while using AJAX which now get sent out after switching to cron.
How to clear a message queue?
