- Use web updater of an older OC 10.7.0.4 installation to upgrade to 10.8.0 fails.
Upgrade from 10.7.0.4 to 10.8.0 works
The web updater fails with error message
[error] Deleted 10.8.0.zip due to wrong checksum
FreeBSD13
Apache
MySQL 5.7.37
10.7.0.4
Updated many times from older OC versions, I think started at 7.x
don’t remember, this installation is so old
When I check the owncloud_data/updater-data/download folder, it is empty. When I try to download https://download.owncloud.com/server/stable/owncloud-complete-20210721.zip, rename it to 10.8.0.zip and upload it into the /download folder, the updater process still fails.
I appreciate any advice how I can best safely upgrade my old 10.7.0.4 installation to 10.8.0, and then to 10.9.0 and 10.10.0 afterwards.
Thanks in advance!
