Error in Log: OCA\Market\SyncJob not found
I found this entry in my logfile.
	○ {"reqId":"bbslCzhVKAZA9rFiMvKQ","level":3,"time":"2021-01-28T04:15:03+01:00","remoteAddr":"","user":"--","app":"core","method":"--","url":"--","message":"Exception: {\"Exception\":\"OCP\\\\AppFramework\\\\QueryException\",\"Message\":\"Could not resolve OCA\\\\Market\\\\SyncJob! Class OCA\\\\Market\\\\SyncJob does not exist\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Utility\\\/SimpleContainer.php(110): OC\\\\AppFramework\\\\Utility\\\\SimpleContainer->resolve('OCA\\\\\\\\Market\\\\\\\\Sync...')\\n#1 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/ServerContainer.php(86): OC\\\\AppFramework\\\\Utility\\\\SimpleContainer->query('OCA\\\\\\\\Market\\\\\\\\Sync...')\\n#2 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/BackgroundJob\\\/JobList.php(253): OC\\\\ServerContainer->query('OCA\\\\\\\\Market\\\\\\\\Sync...')\\n#3 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/BackgroundJob\\\/JobList.php(209): OC\\\\BackgroundJob\\\\JobList->buildJob(Array)\\n#4 \\\/var\\\/www\\\/html\\\/owncloud\\\/core\\\/Command\\\/System\\\/Cron.php(114): OC\\\\BackgroundJob\\\\JobList->getNext()\\n#5 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/composer\\\/symfony\\\/console\\\/Command\\\/Command.php(255): OC\\\\Core\\\\Command\\\\System\\\\Cron->execute(Object(Symfony\\\\Component\\\\Console\\\\Input\\\\ArgvInput), Object(Symfony\\\\Component\\\\Console\\\\Output\\\\ConsoleOutput))\\n#6 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/composer\\\/symfony\\\/console\\\/Application.php(1009): Symfony\\\\Component\\\\Console\\\\Command\\\\Command->run(Object(Symfony\\\\Component\\\\Console\\\\Input\\\\ArgvInput), Object(Symfony\\\\Component\\\\Console\\\\Output\\\\ConsoleOutput))\\n#7 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/composer\\\/symfony\\\/console\\\/Application.php(273): Symfony\\\\Component\\\\Console\\\\Application->doRunCommand(Object(OC\\\\Core\\\\Command\\\\System\\\\Cron), Object(Symfony\\\\Component\\\\Console\\\\Input\\\\ArgvInput), Object(Symfony\\\\Component\\\\Console\\\\Output\\\\ConsoleOutput))\\n#8 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/composer\\\/symfony\\\/console\\\/Application.php(149): Symfony\\\\Component\\\\Console\\\\Application->doRun(Object(Symfony\\\\Component\\\\Console\\\\Input\\\\ArgvInput), Object(Symfony\\\\Component\\\\Console\\\\Output\\\\ConsoleOutput))\\n#9 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Console\\\/Application.php(165): Symfony\\\\Component\\\\Console\\\\Application->run(Object(Symfony\\\\Component\\\\Console\\\\Input\\\\ArgvInput), Object(Symfony\\\\Component\\\\Console\\\\Output\\\\ConsoleOutput))\\n#10 \\\/var\\\/www\\\/html\\\/owncloud\\\/console.php(116): OC\\\\Console\\\\Application->run()\\n#11 \\\/var\\\/www\\\/html\\\/owncloud\\\/occ(11): require_once('\\\/var\\\/www\\\/html\\\/o...')\\n#12 {main}\",\"File\":\"\\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Utility\\\/SimpleContainer.php\",\"Line\":96}"}
I check the database: oc_jobs and found this two entries for the market
|    5 | OCA\Market\SyncJob                         | null  |          0 | 1611803703 | 1611803703 |  -1 |
| 1772 | OCA\Market\CheckUpdateBackgroundJob        | null  | 1611780309 | 1611828907 |          0 |   1 |
Can I safely delete the first entry?
oC version: 10.6.0
market version: 0.6.0
I found an entry with “SyncJob”, but for CardDAV.
Is it possible that something went wrong during the update? The ID is 5 and that means it is one of the first entries?
I started with one of the first ownCloud 10 versions and then updated it regularly until I am now at 10.6.
I noticed this entry yesterday for the first time, but it was there before the end of October 2020.
I would say yes. The OCA\Market\SyncJob seems to be a zombie from an earlier version of the market app.
I have deleted the entry in the database and the log looks very good.
Thanks for your reply, I already thought so, but wanted a second opinion @alfredb !
