Error installing owncloud
  1. yum install owncloud as root
owncloud installs!
Error: Package: owncloud-9.1.5-1.el7.noarch (epel)
Requires: php-zip
followed by a bunch of file not found errors
When I tell it to install php-zip it says that the program is obsolete by another program that is already installed, so it doesn’t install it.
Output of yum install php-zip:
Package php72w-common-7.2.24-1.w7.x86_64 is obsoleted by php-common-7.2.25-1.el7.remi.x86_64 which is already installed
centos 7
see above
newest
fresh install
and tried epel repo
none
Are you using external storage, if yes which one: local/smb/sftp/… yes, but I’m not there yet
Are you using encryption: no
I think you are using a no longer maintained repository, which has old an ownCloud version.
I would recommend you try adding the RHEL 7 repo to your CentOS box and try again. It should let you install the most recent version.
i even think that this is not a package provided by ownCloud but from another third party repository:
