Error login on owncloud after upgrade from 10_8.X to 10_11.X
Hi, guys thans for time and help, after upgrading from 10.8 to 10.11 i It is impossible for me to log in, I put the username and password and it returns me to the login window without errors or without indicating the wrong username and password.
OS: CentOS Linux release 7.9.2009 (Core)
WebServer: Server version: Apache/2.4.6 (CentOS)
PHP: PHP 7.3.33 (cli) (built: Jun 7 2022 08:45:21) ( NTS )
1 - i set the loggin to verbose or everithing and i don’t see any error on the log
2 - Delete Cache
3 - Private navigation
4 - Diferente PC, WEB Explorer
5 - Restart Server
Same Result
You didn’t tell something about your upgrading. I assume something failed there.
Hard to believe. Which one, php log or ownCloud log. Please give more info.
unable to upload file say the forum system, next logs from owncloud.log
{“reqId”:“YzLecjQYo1CAKHChObmp6QAAAAI”,“level”:0,“time”:“2022-09-27T11:28:50+00:00”,“remoteAddr”:“179.52.30.201”,“user”:“–”,“app”:“OC\User\Session::login”,“method”:“POST”,“url”:“/index.php/login?user=admin”,“message”:“regenerating session id for uid argonzalez, password set”}
{“reqId”:“YzLecjQYo1CAKHChObmp6QAAAAI”,“level”:0,“time”:“2022-09-27T11:28:50+00:00”,“remoteAddr”:“179.52.30.201”,“user”:“–”,“app”:“OC\Authentication\Token\DefaultTokenProvider::getToken”,“method”:“POST”,“url”:“/index.php/login?user=argonzalez”,“message”:“token 55ce771cf1fb615be027b1fee5c7ad7b222dec741f5d69020952d100adb241f4a27f77fdc774710688ff75bff801ec8ca794b1bddec15a5c8e4acd3a7aa589ff does not exist”}
{“reqId”:“YzLecjQYo1CAKHChObmp6QAAAAI”,“level”:0,“time”:“2022-09-27T11:28:50+00:00”,“remoteAddr”:“179.52.30.201”,“user”:“–”,“app”:“OC\User\Session::validateToken”,“method”:“POST”,“url”:“/index.php/login?user=admin”,“message”:“token 55ce771cf1fb615be027b1fee5c7ad7b222dec741f5d69020952d100adb241f4a27f77fdc774710688ff75bff801ec8ca794b1bddec15a5c8e4acd3a7aa589ff, not found”}
{“reqId”:“YzLecjQYo1CAKHChObmp6QAAAAI”,“level”:2,“time”:“2022-09-27T11:28:50+00:00”,“remoteAddr”:“179.52.30.201”,“user”:“–”,“app”:“core”,“method”:“POST”,“url”:“/index.php/login?user=admin”,“message”:“Login failed: ‘admin’ (Remote IP: ‘179.52.30.201’)”}
{“reqId”:“YzLect5DUnprFLZFrZSRMQAAAAM”,“level”:0,“time”:“2022-09-27T11:28:50+00:00”,“remoteAddr”:“179.52.30.201”,“user”:“–”,“app”:“OC\Authentication\Token\DefaultTokenProvider::invalidateToken”,“method”:“GET”,“url”:“/index.php/login?user=argonzalez”,“message”:“invalidating token c05a42588f31f9405be66cecab76578312ea56534bc4d59127c1d18619e5383dbe98ea844d25fda9469634a1f51144e50b42603c0a275c69f1df6d0bda5c1ebe”}
{“reqId”:“YzLecx@uU-XHP0U8G1NHMAAAAAA”,“level”:0,“time”:“2022-09-27T11:28:51+00:00”,“remoteAddr”:“179.52.30.201”,“user”:“–”,“app”:“cron”,“method”:“GET”,“url”:“/index.php/cron”,“message”:“Started background job of class : OC\Command\CommandJob with arguments : O:33:"OCA\Files_Versions\Command\Expire":2:{s:43:"\u0000OCA\Files_Versions\Command\Expire\u0000fileName";s:82:"/DONE/BDIDO-629/BRANCHES-BDI-WEB-APP-QAT/app/module/donations/assets/donations.svg";s:39:"\u0000OCA\Files_Versions\Command\Expire\u0000user";s:3:"sii";}”}
{“reqId”:“YzLecx@uU-XHP0U8G1NHMAAAAAA”,“level”:0,“time”:“2022-09-27T11:28:51+00:00”,“remoteAddr”:“179.52.30.201”,“user”:“–”,“app”:“cron”,“method”:“GET”,“url”:“/index.php/cron”,“message”:“Finished background job, the job took : 0 seconds, this job is an instance of class : OC\Command\CommandJob with arguments : O:33:"OCA\Files_Versions\Command\Expire":2:{s:43:"\u0000OCA\Files_Versions\Command\Expire\u0000fileName";s:82:"/DONE/BDIDO-629/BRANCHES-BDI-WEB-APP-QAT/app/module/donations/assets/donations.svg";s:39:"\u0000OCA\Files_Versions\Command\Expire\u0000user";s:3:"sii";}”}
