I have been following the guide to install docker image server on a linux as documented at this link https://doc.owncloud.com/server/admin_manual/installation/docker/ but on the final step I get the following error:
ERROR: manifest for owncloud/server:10.4 not found:
I am using Ubuntu 18.04.3 LTS (GNU/Linux 4.15.0-58-generic x86_64) on a VPS provided by Aruba.
I am not an expert on Linux but have been using a number of docker images in the past with no major issue. Here I was unable to find a solution for this error with the installation process.
- access my linux server and mkdir owncloud-docker-server
- cd owncloud-docker-server
- download the docker-compose yml as instructed
- create the .env file
- run docker-compose up -d
after the docker-compose up -d I would expect to see the composer running
if I run docker-compose ps I see
Name Command State Ports
root@MyServer:/owncloud-docker-server#
Ubuntu 18.04.3 LTS
I assume 10.4
