Error messages due to Sabre
Can somebody please advise the best way to correct this?
Thank you in advance
  1. Sabre error in log file
  2. fails when performing code-check
n/a
error messages constantly outputted
Operating system: Debian Linux 8
Web server: Apache version 2.4.10
Database: MySQL version 5.5.50
PHP version: 5.6.24
ownCloud version (see ownCloud admin page): 9.1.0.15
Updated from an older ownCloud or fresh install: maintained using apt-get
ownCloud log:
Error	PHP	Unsupported operand types at /var/www/owncloud/3rdparty/sabre/uri/lib/functions.php#205	2016-07-27T11:11:59+00:00
Error	PHP	Unsupported operand types at /var/www/owncloud/3rdparty/sabre/uri/lib/functions.php#205	2016-07-27T11:10:59+00:00
Error	PHP	Unsupported operand types at /var/www/owncloud/3rdparty/sabre/uri/lib/functions.php#205	2016-07-27T11:10:00+00:00
Error	PHP	Unsupported operand types at /var/www/owncloud/3rdparty/sabre/uri/lib/functions.php#205	2016-07-27T11:09:59+00:00
Fatal	webdav	Exception: {"Message":"HTTP\/1.1 400 expected filesize 569266 got 32768","Exception":"Sabre\\DAV\\Exception\\BadRequest","Code":0,"Trace":"#0 \/var\/www\/owncloud\/apps\/dav\/lib\/Connector\/Sabre\/Directory.php(136): OCA\\DAV\\Connector\\Sabre\\File->put(Resource id #119)\n#1 \/var\/www\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(1036): OCA\\DAV\\Connector\\Sabre\\Directory->createFile('Jun05-11', Resource id #119)\n#2 \/var\/www\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/CorePlugin.php(523): Sabre\\DAV\\Server->createFile('BBR mag\/111 - 1...', Resource id #119, NULL)\n#3 [internal function]: Sabre\\DAV\\CorePlugin->httpPut(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#4 \/var\/www\/owncloud\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#5 \/var\/www\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(459): Sabre\\Event\\EventEmitter->emit('method:PUT', Array)\n#6 \/var\/www\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(248): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#7 \/var\/www\/owncloud\/apps\/dav\/appinfo\/v1\/webdav.php(56): Sabre\\DAV\\Server->exec()\n#8 \/var\/www\/owncloud\/remote.php(164): require_once('\/var\/www\/ownclo...')\n#9 {main}","File":"\/var\/www\/owncloud\/apps\/dav\/lib\/Connector\/Sabre\/File.php","Line":149,"User":"bbroffice"}	2016-07-27T11:08:59+00:00
When performing the following:
sudo -u www-data php occ app:check-code dav
I get…
Analysing /var/www/owncloud/apps/dav/lib/CalDAV/CalDavBackend.php
 1 errors
    line  781: == - is discouraged
Analysing /var/www/owncloud/apps/dav/lib/CardDAV/CardDavBackend.php
 2 errors
    line  910: == - is discouraged
Analysing /var/www/owncloud/apps/dav/lib/DAV/Sharing/Backend.php
 1 errors
    line  164: == - is discouraged
Analysing /var/www/owncloud/apps/dav/lib/Connector/Sabre/Node.php
 1 errors
    line  217: OC_Util - Static method of private class must not be called
Analysing /var/www/owncloud/apps/dav/lib/Connector/Sabre/ObjectTree.php
 2 errors
    line   81: == - is discouraged
Analysing /var/www/owncloud/apps/dav/lib/Connector/Sabre/ExceptionLoggerPlugin.php
 1 errors
    line  100: OC_User - Static method of private class must not be called
Analysing /var/www/owncloud/apps/dav/lib/Connector/Sabre/Directory.php
 2 errors
    line  208: == - is discouraged
    line  297: OC_Helper - Static method of private class must not be called
Analysing /var/www/owncloud/apps/dav/lib/Connector/Sabre/File.php
 9 errors
    line  132: OC_Helper - Static method of private class must not be called
    line  148: != - is discouraged
    line  255: OC_Hook - Static method of private class must not be called
    line  260: OC_Hook - Static method of private class must not be called
    line  265: OC_Hook - Static method of private class must not be called
    line  281: OC_Hook - Static method of private class must not be called
    line  285: OC_Hook - Static method of private class must not be called
    line  289: OC_Hook - Static method of private class must not be called
    line  402: != - is discouraged
Analysing /var/www/owncloud/apps/dav/lib/Connector/Sabre/Auth.php
 5 errors
    line  115: OC_Util - Static method of private class must not be called
    line  119: OC_Util - Static method of private class must not be called
    line  122: OC_Util - Static method of private class must not be called
    line  221: OC_User - Static method of private class must not be called
    line  228: OC_Util - Static method of private class must not be called
Analysing /var/www/owncloud/apps/dav/lib/Connector/PublicAuth.php
 1 errors
    line   93: OC_User - Static method of private class must not be called
Analysing /var/www/owncloud/apps/dav/lib/Files/BrowserErrorPagePlugin.php
 2 errors
    line   26: OC_Template - private class must not be imported with a use statement
    line   96: OC_Template - private class must not be instantiated
Analysing /var/www/owncloud/apps/dav/appinfo/v1/webdav.php
 1 errors
    line   28: OC_Util - Static method of private class must not be called
Analysing /var/www/owncloud/apps/dav/appinfo/v1/publicwebdav.php
 3 errors
    line   32: OC_App - Static method of private class must not be called
    line   34: OC_Util - Static method of private class must not be called
    line   75: OC_Util - Static method of private class must not be called
Analysing /var/www/owncloud/apps/dav/appinfo/v2/remote.php
 1 errors
    line   25: OC_Util - Static method of private class must not be called
App is not compliant
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption): none
Integrity status for oC9+
This is a known bug reported at the bugtracker:
