I’m new to the owncloud community
I just installed my first owncloud server on a nas synology.
From an iOS phone, I successfully connect to my owncloud server.
On Android, I encounter an error message when I enter the URL to connect to my server.
I have this error message: rename_local_fail_msg, in french: “La version locale ne peut pas être renommée, veuillez réessayer avec un nom différent”
I downloaded the latest version of the software from the play store
My owncloud server is in version 10.3.1
I did not find an answer to this error, can you help me?
Have a nice day,
yoyohand
Thank’s for you answer.
I have found the cause of my problem but do not know how to solve it at the moment.
From internet, if I don’t add in my url “/owncloud” I arrive on the home page of my web server.
On ios devices redirection is done automatically to owncloud, not to android. I must find the solution to arrive on the owncloud home page without adding “/owncloud” in my web url
The connexion works now, I will test transfer files later, if I do not return to this topic is that the solution is approved ;)! Thank you for your help,
