think now it complains about my key which is correct
{"reqId":"YHsQtKG3so8NKazSFkbC","level":3,"time":"2020-04-17T18:16:24-04:00","remoteAddr":"24.185.167.129","user":"oc1","app":"files_external","method":"PUT","url":"\/index.php\/apps\/files_external\/globalstorages\/1","message":"Exception: {\"Exception\":\"Aws\\\\S3\\\\Exception\\\\S3Exception\",\"Message\":\"Error executing \\\"CreateBucket\\\" on \\\"https:\\\/\\\/s3.amazonaws.com\\\/%2Fmnt%2Focfiles\\\"; AWS HTTP error: Client error response [url] https:\\\/\\\/s3.amazonaws.com\\\/%2Fmnt%2Focfiles [status code] 403 [reason phrase] Forbidden SignatureDoesNotMatch (client): The request signature we calculated does not match the signature you provided. Check your key and signing method. - <?xml version=\\\"1.0\\\" encoding=\\\"UTF-8\\\"?>\\n<Error><Code>SignatureDoesNotMatch<\\\/Code><Message>The request signature we calculated does not match the signature you provided. Check your key and signing method.<\\\/Message><AWSAccessKeyId>AKIAJAZYPCIIGX6MWC4A<\\\/AWSAccessKeyId><StringToSign>AWS4-HMAC-SHA256\\n20200417T221624Z\\n20200417\\\/us-east-1\\\/s3\\\/aws4_request\\nc30ba6d66b074cfbdb686c84b3d8ce35320b20bff96bada546ae26c91f2039f8<\\\/StringToSign><SignatureProvided>875103f18f9ae735bcb905fc27fdad1a4d27c73dd33541872868c12201bd9950<\\\/SignatureProvided><StringToSignBytes>41 57 53 34 2d 48 4d 41 43 2d 53 48 41 32 35 36 0a 32 30 32 30 30 34 31 37 54 32 32 31 36 32 34 5a 0a 32 30 32 30 30 34 31 37 2f 75 73 2d 65 61 73 74 2d 31 2f 73 33 2f 61 77 73 34 5f 72 65 71 75 65 73 74 0a 63 33 30 62 61 36 64 36 36 62 30 37 34 63 66 62 64 62 36 38 36 63 38 34 62 33 64 38 63 65 33 35 33 32 30 62 32 30 62 66 66 39 36 62 61 64 61 35 34 36 61 65 32 36 63 39 31 66 32 30 33 39 66 38<\\\/StringToSignBytes><CanonicalRequest>PUT\\n\\\/\\\/mnt\\\/ocfiles\\n\\nhost:s3.amazonaws.com\\nx-amz-content-sha256:e3b0c44298fc1c149afbf4c8996fb92427ae41e4649b934ca495991b7852b855\\nx-amz-date:20200417T221624Z\\n\\nhost;x-amz-content-sha256;x-amz-date\\ne3b0c44298fc1c149afbf4c8996fb92427ae41e4649b934ca495991b7852b855<\\\/CanonicalRequest><CanonicalRequestBytes>50 55 54 0a 2f 2f 6d 6e 74 2f 6f 63 66 69 6c 65 73 0a 0a 68 6f 73 74 3a 73 33 2e 61 6d 61 7a 6f 6e 61 77 73 2e 63 6f 6d 0a 78 2d 61 6d 7a 2d 63 6f 6e 74 65 6e 74 2d 73 68 61 32 35 36 3a 65 33 62 30 63 34 34 32 39 38 66 63 31 63 31 34 39 61 66 62 66 34 63 38 39 39 36 66 62 39 32 34 32 37 61 65 34 31 65 34 36 34 39 62 39 33 34 63 61 34 39 35 39 39 31 62 37 38 35 32 62 38 35 35 0a 78 2d 61 6d 7a 2d 64 61 74 65 3a 32 30 32 30 30 34 31 37 54 32 32 31 36 32 34 5a 0a 0a 68 6f 73 74 3b 78 2d 61 6d 7a 2d 63 6f 6e 74 65 6e 74 2d 73 68 61 32 35 36 3b 78 2d 61 6d 7a 2d 64 61 74 65 0a 65 33 62 30 63 34 34 32 39 38 66 63 31 63 31 34 39 61 66 62 66 34 63 38 39 39 36 66 62 39 32 34 32 37 61 65 34 31 65 34 36 34 39 62 39 33 34 63 61 34 39 35 39 39 31 62 37 38 35 32 62 38 35 35<\\\/CanonicalRequestBytes><RequestId>47494ADCB427B91D<\\\/RequestId><HostId>OKUj9GMq7VVd9NImBHAViuwGSSXjEkmB0AfNX0HgmF0wGpH7b9RCq+mPWHGPll6rVtEAJW2aY+I=<\\\/HostId><\\\/Error>\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/aws\\\/aws-sdk-php\\\/src\\\/WrappedHttpHandler.php(97): Aws\\\\WrappedHttpHandler->parseError(Array, Object(GuzzleHttp\\\\Psr7\\\\Request), Object(Aws\\\\Command), Array)\\n#1 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/guzzlehttp\\\/promises\\\/src\\\/Promise.php(203): Aws\\\\WrappedHttpHandler->Aws\\\\{closure}(Array)\\n#2 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/guzzlehttp\\\/promises\\\/src\\\/Promise.php(174): GuzzleHttp\\\\Promise\\\\Promise::callHandler(2, Array, Array)\\n#3 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/guzzlehttp\\\/promises\\\/src\\\/RejectedPromise.php(40): GuzzleHttp\\\\Promise\\\\Promise::GuzzleHttp\\\\Promise\\\\{closure}(Array)\\n#4 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/guzzlehttp\\\/promises\\\/src\\\/TaskQueue.php(47): GuzzleHttp\\\\Promise\\\\RejectedPromise::GuzzleHttp\\\\Promise\\\\{closure}()\\n#5 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/guzzlehttp\\\/promises\\\/src\\\/Promise.php(246): GuzzleHttp\\\\Promise\\\\TaskQueue->run(true)\\n#6 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/guzzlehttp\\\/promises\\\/src\\\/Promise.php(223): GuzzleHttp\\\\Promise\\\\Promise->invokeWaitFn()\\n#7 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/guzzlehttp\\\/promises\\\/src\\\/Promise.php(267): GuzzleHttp\\\\Promise\\\\Promise->waitIfPending()\\n#8 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/guzzlehttp\\\/promises\\\/src\\\/Promise.php(225): GuzzleHttp\\\\Promise\\\\Promise->invokeWaitList()\\n#9 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/guzzlehttp\\\/promises\\\/src\\\/Promise.php(62): GuzzleHttp\\\\Promise\\\\Promise->waitIfPending()\\n#10 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/aws\\\/aws-sdk-php\\\/src\\\/AwsClientTrait.php(58): GuzzleHttp\\\\Promise\\\\Promise->wait()\\n#11 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/aws\\\/aws-sdk-php\\\/src\\\/AwsClientTrait.php(86): Aws\\\\AwsClient->execute(Object(Aws\\\\Command))\\n#12 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/lib\\\/Storage\\\/AmazonS3.php(609): Aws\\\\AwsClient->__call('createBucket', Array)\\n#13 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/lib\\\/Storage\\\/AmazonS3.php(534): OCA\\\\FilesExternalS3\\\\Storage\\\\AmazonS3->getConnection()\\n#14 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Files\\\/External\\\/LegacyUtil.php(207): OCA\\\\FilesExternalS3\\\\Storage\\\\AmazonS3->test(false, true)\\n#15 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Controller\\\/StoragesController.php(251): OC\\\\Files\\\\External\\\\LegacyUtil::getBackendStatus('OCA\\\\\\\\FilesExtern...', Array, false, true)\\n#16 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Controller\\\/GlobalStoragesController.php(186): OCA\\\\Files_External\\\\Controller\\\\StoragesController->updateStorageStatus(Object(OC\\\\Files\\\\External\\\\StorageConfig), true)\\n#17 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Http\\\/Dispatcher.php(153): OCA\\\\Files_External\\\\Controller\\\\GlobalStoragesController->update(1, 'ocfiles ', 'files_external_...', 'amazons3::acces...', Array, Array, Array, Array, 100, true)\\n#18 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Http\\\/Dispatcher.php(85): OC\\\\AppFramework\\\\Http\\\\Dispatcher->executeController(Object(OCA\\\\Files_External\\\\Controller\\\\GlobalStoragesController), 'update')\\n#19 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/App.php(100): OC\\\\AppFramework\\\\Http\\\\Dispatcher->dispatch(Object(OCA\\\\Files_External\\\\Controller\\\\GlobalStoragesController), 'update')\\n#20 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Routing\\\/RouteActionHandler.php(47): OC\\\\AppFramework\\\\App::main('OCA\\\\\\\\Files_Exter...', 'update', Object(OC\\\\AppFramework\\\\DependencyInjection\\\\DIContainer), Array)\\n#21 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Route\\\/Router.php(342): OC\\\\AppFramework\\\\Routing\\\\RouteActionHandler->__invoke(Array)\\n#22 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/base.php(920): OC\\\\Route\\\\Router->match('\\\/apps\\\/files_ext...')\\n#23 \\\/var\\\/www\\\/html\\\/owncloud\\\/index.php(54): OC::handleRequest()\\n#24 {main}\",\"File\":\"\\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/aws\\\/aws-sdk-php\\\/src\\\/WrappedHttpHandler.php\",\"Line\":195}"}
{"reqId":"YHsQtKG3so8NKazSFkbC","level":3,"time":"2020-04-17T18:16:24-04:00","remoteAddr":"24.185.167.129","user":"oc1","app":"files_external","method":"PUT","url":"\/index.php\/apps\/files_external\/globalstorages\/1","message":"Caused by: {\"Exception\":\"GuzzleHttp\\\\Exception\\\\ClientException\",\"Message\":\"Client error response [url] https:\\\/\\\/s3.amazonaws.com\\\/%2Fmnt%2Focfiles [status code] 403 [reason phrase] Forbidden\",\"Code\":403,\"Trace\":\"#0 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/composer\\\/guzzlehttp\\\/guzzle\\\/src\\\/Subscriber\\\/HttpError.php(32): GuzzleHttp\\\\Exception\\\\RequestException::create(Object(GuzzleHttp\\\\Message\\\\Request), Object(GuzzleHttp\\\\Message\\\\Response))\\n#1 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/composer\\\/guzzlehttp\\\/guzzle\\\/src\\\/Event\\\/Emitter.php(108): GuzzleHttp\\\\Subscriber\\\\HttpError->onComplete(Object(GuzzleHttp\\\\Event\\\\CompleteEvent), 'complete')\\n#2 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/composer\\\/guzzlehttp\\\/guzzle\\\/src\\\/RequestFsm.php(91): GuzzleHttp\\\\Event\\\\Emitter->emit('complete', Object(GuzzleHttp\\\\Event\\\\CompleteEvent))\\n#3 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/composer\\\/guzzlehttp\\\/guzzle\\\/src\\\/RequestFsm.php(132): GuzzleHttp\\\\RequestFsm->__invoke(Object(GuzzleHttp\\\\Transaction))\\n#4 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/composer\\\/react\\\/promise\\\/src\\\/FulfilledPromise.php(25): GuzzleHttp\\\\RequestFsm->GuzzleHttp\\\\{closure}(Array)\\n#5 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/composer\\\/guzzlehttp\\\/ringphp\\\/src\\\/Future\\\/CompletedFutureValue.php(55): React\\\\Promise\\\\FulfilledPromise->then(Object(Closure), NULL, NULL)\\n#6 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/composer\\\/guzzlehttp\\\/guzzle\\\/src\\\/Message\\\/FutureResponse.php(43): GuzzleHttp\\\\Ring\\\\Future\\\\CompletedFutureValue->then(Object(Closure), NULL, NULL)\\n#7 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/composer\\\/guzzlehttp\\\/guzzle\\\/src\\\/RequestFsm.php(134): GuzzleHttp\\\\Message\\\\FutureResponse::proxy(Object(GuzzleHttp\\\\Ring\\\\Future\\\\CompletedFutureArray), Object(Closure))\\n#8 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/composer\\\/guzzlehttp\\\/guzzle\\\/src\\\/Client.php(165): GuzzleHttp\\\\RequestFsm->__invoke(Object(GuzzleHttp\\\\Transaction))\\n#9 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/aws\\\/aws-sdk-php\\\/src\\\/Handler\\\/GuzzleV5\\\/GuzzleHandler.php(62): GuzzleHttp\\\\Client->send(Object(GuzzleHttp\\\\Message\\\\Request))\\n#10 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/aws\\\/aws-sdk-php\\\/src\\\/WrappedHttpHandler.php(87): Aws\\\\Handler\\\\GuzzleV5\\\\GuzzleHandler->__invoke(Object(GuzzleHttp\\\\Psr7\\\\Request), Array)\\n#11 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/aws\\\/aws-sdk-php\\\/src\\\/ClientSideMonitoring\\\/AbstractMonitoringMiddleware.php(126): Aws\\\\WrappedHttpHandler->__invoke(Object(Aws\\\\Command), Object(GuzzleHttp\\\\Psr7\\\\Request))\\n#12 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/aws\\\/aws-sdk-php\\\/src\\\/S3\\\/PermanentRedirectMiddleware.php(43): Aws\\\\ClientSideMonitoring\\\\AbstractMonitoringMiddleware->__invoke(Object(Aws\\\\Command), Object(GuzzleHttp\\\\Psr7\\\\Request))\\n#13 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/aws\\\/aws-sdk-php\\\/src\\\/S3\\\/PutObjectUrlMiddleware.php(41): Aws\\\\S3\\\\PermanentRedirectMiddleware->__invoke(Object(Aws\\\\Command), Object(GuzzleHttp\\\\Psr7\\\\Request))\\n#14 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/aws\\\/aws-sdk-php\\\/src\\\/Middleware.php(126): Aws\\\\S3\\\\PutObjectUrlMiddleware->__invoke(Object(Aws\\\\Command), Object(GuzzleHttp\\\\Psr7\\\\Request))\\n#15 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/guzzlehttp\\\/promises\\\/src\\\/FulfilledPromise.php(39): Aws\\\\Middleware::Aws\\\\{closure}(Object(Aws\\\\Credentials\\\\Credentials))\\n#16 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/guzzlehttp\\\/promises\\\/src\\\/TaskQueue.php(47): GuzzleHttp\\\\Promise\\\\FulfilledPromise::GuzzleHttp\\\\Promise\\\\{closure}()\\n#17 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/guzzlehttp\\\/promises\\\/src\\\/Promise.php(246): GuzzleHttp\\\\Promise\\\\TaskQueue->run(true)\\n#18 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/guzzlehttp\\\/promises\\\/src\\\/Promise.php(223): GuzzleHttp\\\\Promise\\\\Promise->invokeWaitFn()\\n#19 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/guzzlehttp\\\/promises\\\/src\\\/Promise.php(267): GuzzleHttp\\\\Promise\\\\Promise->waitIfPending()\\n#20 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/guzzlehttp\\\/promises\\\/src\\\/Promise.php(225): GuzzleHttp\\\\Promise\\\\Promise->invokeWaitList()\\n#21 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/guzzlehttp\\\/promises\\\/src\\\/Promise.php(62): GuzzleHttp\\\\Promise\\\\Promise->waitIfPending()\\n#22 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/aws\\\/aws-sdk-php\\\/src\\\/AwsClientTrait.php(58): GuzzleHttp\\\\Promise\\\\Promise->wait()\\n#23 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/vendor\\\/aws\\\/aws-sdk-php\\\/src\\\/AwsClientTrait.php(86): Aws\\\\AwsClient->execute(Object(Aws\\\\Command))\\n#24 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/lib\\\/Storage\\\/AmazonS3.php(609): Aws\\\\AwsClient->__call('createBucket', Array)\\n#25 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/lib\\\/Storage\\\/AmazonS3.php(534): OCA\\\\FilesExternalS3\\\\Storage\\\\AmazonS3->getConnection()\\n#26 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Files\\\/External\\\/LegacyUtil.php(207): OCA\\\\FilesExternalS3\\\\Storage\\\\AmazonS3->test(false, true)\\n#27 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Controller\\\/StoragesController.php(251): OC\\\\Files\\\\External\\\\LegacyUtil::getBackendStatus('OCA\\\\\\\\FilesExtern...', Array, false, true)\\n#28 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Controller\\\/GlobalStoragesController.php(186): OCA\\\\Files_External\\\\Controller\\\\StoragesController->updateStorageStatus(Object(OC\\\\Files\\\\External\\\\StorageConfig), true)\\n#29 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Http\\\/Dispatcher.php(153): OCA\\\\Files_External\\\\Controller\\\\GlobalStoragesController->update(1, 'ocfiles ', 'files_external_...', 'amazons3::acces...', Array, Array, Array, Array, 100, true)\\n#30 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Http\\\/Dispatcher.php(85): OC\\\\AppFramework\\\\Http\\\\Dispatcher->executeController(Object(OCA\\\\Files_External\\\\Controller\\\\GlobalStoragesController), 'update')\\n#31 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/App.php(100): OC\\\\AppFramework\\\\Http\\\\Dispatcher->dispatch(Object(OCA\\\\Files_External\\\\Controller\\\\GlobalStoragesController), 'update')\\n#32 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Routing\\\/RouteActionHandler.php(47): OC\\\\AppFramework\\\\App::main('OCA\\\\\\\\Files_Exter...', 'update', Object(OC\\\\AppFramework\\\\DependencyInjection\\\\DIContainer), Array)\\n#33 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Route\\\/Router.php(342): OC\\\\AppFramework\\\\Routing\\\\RouteActionHandler->__invoke(Array)\\n#34 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/base.php(920): OC\\\\Route\\\\Router->match('\\\/apps\\\/files_ext...')\\n#35 \\\/var\\\/www\\\/html\\\/owncloud\\\/index.php(54): OC::handleRequest()\\n#36 {main}\",\"File\":\"\\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/composer\\\/guzzlehttp\\\/guzzle\\\/src\\\/Exception\\\/RequestException.php\",\"Line\":89}"}
{"reqId":"YHsQtKG3so8NKazSFkbC","level":3,"time":"2020-04-17T18:16:24-04:00","remoteAddr":"24.185.167.129","user":"oc1","app":"files_external","method":"PUT","url":"\/index.php\/apps\/files_external\/globalstorages\/1","message":"Exception: {\"Exception\":\"Exception\",\"Message\":\"Creation of bucket failed. Error executing \\\"CreateBucket\\\" on \\\"https:\\\/\\\/s3.amazonaws.com\\\/%2Fmnt%2Focfiles\\\"; AWS HTTP error: Client error response [url] https:\\\/\\\/s3.amazonaws.com\\\/%2Fmnt%2Focfiles [status code] 403 [reason phrase] Forbidden SignatureDoesNotMatch (client): The request signature we calculated does not match the signature you provided. Check your key and signing method. - <?xml version=\\\"1.0\\\" encoding=\\\"UTF-8\\\"?>\\n<Error><Code>SignatureDoesNotMatch<\\\/Code><Message>The request signature we calculated does not match the signature you provided. Check your key and signing method.<\\\/Message><AWSAccessKeyId>AKIAJAZYPCIIGX6MWC4A<\\\/AWSAccessKeyId><StringToSign>AWS4-HMAC-SHA256\\n20200417T221624Z\\n20200417\\\/us-east-1\\\/s3\\\/aws4_request\\nc30ba6d66b074cfbdb686c84b3d8ce35320b20bff96bada546ae26c91f2039f8<\\\/StringToSign><SignatureProvided>875103f18f9ae735bcb905fc27fdad1a4d27c73dd33541872868c12201bd9950<\\\/SignatureProvided><StringToSignBytes>41 57 53 34 2d 48 4d 41 43 2d 53 48 41 32 35 36 0a 32 30 32 30 30 34 31 37 54 32 32 31 36 32 34 5a 0a 32 30 32 30 30 34 31 37 2f 75 73 2d 65 61 73 74 2d 31 2f 73 33 2f 61 77 73 34 5f 72 65 71 75 65 73 74 0a 63 33 30 62 61 36 64 36 36 62 30 37 34 63 66 62 64 62 36 38 36 63 38 34 62 33 64 38 63 65 33 35 33 32 30 62 32 30 62 66 66 39 36 62 61 64 61 35 34 36 61 65 32 36 63 39 31 66 32 30 33 39 66 38<\\\/StringToSignBytes><CanonicalRequest>PUT\\n\\\/\\\/mnt\\\/ocfiles\\n\\nhost:s3.amazonaws.com\\nx-amz-content-sha256:e3b0c44298fc1c149afbf4c8996fb92427ae41e4649b934ca495991b7852b855\\nx-amz-date:20200417T221624Z\\n\\nhost;x-amz-content-sha256;x-amz-date\\ne3b0c44298fc1c149afbf4c8996fb92427ae41e4649b934ca495991b7852b855<\\\/CanonicalRequest><CanonicalRequestBytes>50 55 54 0a 2f 2f 6d 6e 74 2f 6f 63 66 69 6c 65 73 0a 0a 68 6f 73 74 3a 73 33 2e 61 6d 61 7a 6f 6e 61 77 73 2e 63 6f 6d 0a 78 2d 61 6d 7a 2d 63 6f 6e 74 65 6e 74 2d 73 68 61 32 35 36 3a 65 33 62 30 63 34 34 32 39 38 66 63 31 63 31 34 39 61 66 62 66 34 63 38 39 39 36 66 62 39 32 34 32 37 61 65 34 31 65 34 36 34 39 62 39 33 34 63 61 34 39 35 39 39 31 62 37 38 35 32 62 38 35 35 0a 78 2d 61 6d 7a 2d 64 61 74 65 3a 32 30 32 30 30 34 31 37 54 32 32 31 36 32 34 5a 0a 0a 68 6f 73 74 3b 78 2d 61 6d 7a 2d 63 6f 6e 74 65 6e 74 2d 73 68 61 32 35 36 3b 78 2d 61 6d 7a 2d 64 61 74 65 0a 65 33 62 30 63 34 34 32 39 38 66 63 31 63 31 34 39 61 66 62 66 34 63 38 39 39 36 66 62 39 32 34 32 37 61 65 34 31 65 34 36 34 39 62 39 33 34 63 61 34 39 35 39 39 31 62 37 38 35 32 62 38 35 35<\\\/CanonicalRequestBytes><RequestId>47494ADCB427B91D<\\\/RequestId><HostId>OKUj9GMq7VVd9NImBHAViuwGSSXjEkmB0AfNX0HgmF0wGpH7b9RCq+mPWHGPll6rVtEAJW2aY+I=<\\\/HostId><\\\/Error>\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/lib\\\/Storage\\\/AmazonS3.php(534): OCA\\\\FilesExternalS3\\\\Storage\\\\AmazonS3->getConnection()\\n#1 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Files\\\/External\\\/LegacyUtil.php(207): OCA\\\\FilesExternalS3\\\\Storage\\\\AmazonS3->test(false, true)\\n#2 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Controller\\\/StoragesController.php(251): OC\\\\Files\\\\External\\\\LegacyUtil::getBackendStatus('OCA\\\\\\\\FilesExtern...', Array, false, true)\\n#3 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Controller\\\/GlobalStoragesController.php(186): OCA\\\\Files_External\\\\Controller\\\\StoragesController->updateStorageStatus(Object(OC\\\\Files\\\\External\\\\StorageConfig), true)\\n#4 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Http\\\/Dispatcher.php(153): OCA\\\\Files_External\\\\Controller\\\\GlobalStoragesController->update(1, 'ocfiles ', 'files_external_...', 'amazons3::acces...', Array, Array, Array, Array, 100, true)\\n#5 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Http\\\/Dispatcher.php(85): OC\\\\AppFramework\\\\Http\\\\Dispatcher->executeController(Object(OCA\\\\Files_External\\\\Controller\\\\GlobalStoragesController), 'update')\\n#6 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/App.php(100): OC\\\\AppFramework\\\\Http\\\\Dispatcher->dispatch(Object(OCA\\\\Files_External\\\\Controller\\\\GlobalStoragesController), 'update')\\n#7 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Routing\\\/RouteActionHandler.php(47): OC\\\\AppFramework\\\\App::main('OCA\\\\\\\\Files_Exter...', 'update', Object(OC\\\\AppFramework\\\\DependencyInjection\\\\DIContainer), Array)\\n#8 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Route\\\/Router.php(342): OC\\\\AppFramework\\\\Routing\\\\RouteActionHandler->__invoke(Array)\\n#9 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/base.php(920): OC\\\\Route\\\\Router->match('\\\/apps\\\/files_ext...')\\n#10 \\\/var\\\/www\\\/html\\\/owncloud\\\/index.php(54): OC::handleRequest()\\n#11 {main}\",\"File\":\"\\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external_s3\\\/lib\\\/Storage\\\/AmazonS3.php\",\"Line\":619}"}
any idea what this menans
A refresh token has been used by the client “iOS” to request an access token
"reqId":"469FDEAA-4A43-4E5D-A3F2-0A43F913A676","level":1,"time":"2020-04-17T20:43:32-04:00","remoteAddr":"24.185.167.129","user":"--","app":"oauth2","method":"POST","url":"\/index.php\/apps\/oauth2\/api\/v1\/token","message":"A refresh token has been used by the client \"iOS\" to request an access token."}
