Error uploading file. Problem loading page, reloading in 5 seconds
  1. Click + Upload
  2. Select file
  3. wait a minute
  4. See error: Error uploading file “my-file.extv”:
I can upload a file to about 65MB, larger files always produce this error.
FIle should upload and display in folder in oC
Error message: Error uploading file “my-file.extv”:
Apache Version 2.4.25
PHP Version 5.6.30
MySQL Version 5.5.54-cll
Operating System linux
ownCloud version (see ownCloud admin page): stable
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption): symptom occurs in both external and server based storage
log is empty
Integrity status for oC9+
paste the results here.
Hello
I’m French so excuse me for me english
I’ve the same probleme
When I open inspector on my navigator (freefox)
I can read this error : "Content-Security-Policy : The page’s settings blocked an inline script (script-src-elem) from being executed because it violates the following directive: “script-src ‘self’ ‘unsafe-eval’”
Could you help me to solve the problem ?
owncloud : 10.14.0 (stable)
php 7.4
Thank you
i’m not sure if you noticed that you have posted in a 7 year old thread :slightly_frowning_face:
I think that a new thread for your issue would be suggested (including more details on the environment) as it is not necessarily the same problem like the original poster has.
