So I followed instruction on how to install OwnCloud from DigitalOcean here, https://www.digitalocean.com/community/tutorials/how-to-install-and-configure-owncloud-on-ubuntu-16-04.
Everything went fine, until the last part when I need to create account for the OwnCloud. There is this error.
SQLSTATE[HY000][1045] Access denied for user 'user_test'@'localhost' (using password: yes)
I suspected this is because I input wrong password. However, I can login to ‘user_test’ using MySQL in console fine (via SSH).
I am using Ubuntu 16.04 from DigitalOcean.
I am new to this kind of stuffs. What kind of information that I need to provide?
you need to specify the mysql root user there and then a correct less privileged user is created as explained at the installation guides available at https://doc.owncloud.org
Honestly, I am not sure to which part I should look in. I do have these user in MySQL.
- debian-user-maint
- mysql.sys
- user_test
- root
I can login to user_test and to root via interactive shell.
its the root user as explained (in this little bit hidden) docs:
otherwise you can simply reconfigure whole MySQL (if not any other databases running on this server), by doing this:
sudo dpkg-reconfigure mysql-server
after youve done it, just keep in mind to SAFE your root-password for mysql!
Thank you, I will try this when I get home.
