I’m building the ownCloud client on Ubuntu 16.04. I’m following the steps here. While running apt-get build-dep owncloud-client , I get this error:
The following packages have unmet dependencies: builddeps:owncloud-client : Depends: ocqt562-qt5-qmake but it is not installable Depends: ocqt562-qttools5-dev-tools but it is not installable Depends: ocqt562-qtbase5-dev but it is not installable Depends: ocqt562-qt5keychain-dev (>= 0.7.0) but it is not installable Depends: ocqt562-libqt5webkit5-dev (>= 2.2.0) but it is not installable E: Unable to correct problems, you have held broken packages.
I checked the repository, and it has those *.deb packages present for amd64(my PC). Even apt-get install owncloud-client works correctly.
My sources.list.d/owncloud-client.list file looks like this:
deb-src http://download.opensuse.org/repositories/isv:/ownCloud:/desktop/Ubuntu_16.04/ /
Thanks for your help
