Hello, I’m french, sorry if my english is bad or if don’t understand every thing.
I don’t find ansower on web.
My data are uploaded on FTP with External Storage: FTP.
When the data change on FTP the owncloud are not update.
I find un cmd line but I have this error :
sudo -u www-data php occ files:scan dlt
Exception during scan: ErrorException: Undefined offset: 0
Thank you very much for your help.
Emile
Sync FTP data to owncloud
No sync data from FTP.
➜ owncloud sudo -u www-data php occ files:scan dlt
Scanning files for 1 users
Starting scan for user 1 out of 1 (dlt)
#0 /var/www/owncloud/apps/files_external_ftp/lib/Storage/FTP.php(98): OCA\Files\Command\Scan->exceptionErrorHandler(8, ‘Undefined offse…’, ‘/var/www/ownclo…’, 98, Array)
#1 /var/www/owncloud/lib/private/Files/Storage/Common.php(639): OCA\Files_external_ftp\Storage\FTP->filemtime(‘Mod\xC3\xA8les Office…’)
#2 /var/www/owncloud/lib/private/Files/Storage/Wrapper/Wrapper.php(578): OC\Files\Storage\Common->getMetaData(‘Mod\xC3\xA8les Office…’)
#3 /var/www/owncloud/lib/private/Files/Storage/Wrapper/Wrapper.php(578): OC\Files\Storage\Wrapper\Wrapper->getMetaData(‘Mod\xC3\xA8les Office…’)
#4 /var/www/owncloud/lib/private/Files/Storage/Wrapper/Availability.php(459): OC\Files\Storage\Wrapper\Wrapper->getMetaData(‘Mod\xC3\xA8les Office…’)
#5 /var/www/owncloud/lib/private/Files/Storage/Wrapper/Encryption.php(175): OC\Files\Storage\Wrapper\Availability->getMetaData(‘Mod\xC3\xA8les Office…’)
#6 /var/www/owncloud/lib/private/Files/Storage/Wrapper/Checksum.php(202): OC\Files\Storage\Wrapper\Encryption->getMetaData(‘Mod\xC3\xA8les Office…’)
#7 /var/www/owncloud/lib/private/Files/Storage/Wrapper/Wrapper.php(578): OC\Files\Storage\Wrapper\Checksum->getMetaData(‘Mod\xC3\xA8les Office…’)
#8 /var/www/owncloud/lib/private/Files/Cache/Scanner.php(116): OC\Files\Storage\Wrapper\Wrapper->getMetaData(‘Mod\xC3\xA8les Office…’)
#9 /var/www/owncloud/lib/private/Files/Cache/Scanner.php(153): OC\Files\Cache\Scanner->getData(‘Mod\xC3\xA8les Office…’)
#10 /var/www/owncloud/lib/private/Files/Cache/Scanner.php(427): OC\Files\Cache\Scanner->scanFile(‘Mod\xC3\xA8les Office…’, 3, ‘3685’, Object(OC\Files\Cache\CacheEntry), true)
#11 /var/www/owncloud/lib/private/Files/Cache/Scanner.php(395): OC\Files\Cache\Scanner->handleChildren(’’, true, 3, ‘3685’, true, 2408)
#12 /var/www/owncloud/lib/private/Files/Cache/Scanner.php(328): OC\Files\Cache\Scanner->scanChildren(’’, true, 3, ‘3685’, true)
#13 /var/www/owncloud/lib/private/Files/Utils/Scanner.php(245): OC\Files\Cache\Scanner->scan(’’, true, 3)
#14 /var/www/owncloud/apps/files/lib/Command/Scan.php(245): OC\Files\Utils\Scanner->scan(’/dlt’, false)
#15 /var/www/owncloud/apps/files/lib/Command/Scan.php(392): OCA\Files\Command\Scan->scanFiles(‘dlt’, ‘/dlt’, false, Object(Symfony\Component\Console\Output\ConsoleOutput), false, false)
#16 /var/www/owncloud/apps/files/lib/Command/Scan.php(355): OCA\Files\Command\Scan->userScan(Array, NULL, false, Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput), false)
#17 /var/www/owncloud/apps/files/lib/Command/Scan.php(321): OCA\Files\Command\Scan->processUserChunks(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput), Array, NULL, false)
#18 /var/www/owncloud/lib/composer/symfony/console/Command/Command.php(255): OCA\Files\Command\Scan->execute(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#19 /var/www/owncloud/core/Command/Base.php(159): Symfony\Component\Console\Command\Command->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#20 /var/www/owncloud/lib/composer/symfony/console/Application.php(953): OC\Core\Command\Base->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#21 /var/www/owncloud/lib/composer/symfony/console/Application.php(248): Symfony\Component\Console\Application->doRunCommand(Object(OCA\Files\Command\Scan), Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#22 /var/www/owncloud/lib/composer/symfony/console/Application.php(148): Symfony\Component\Console\Application->doRun(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#23 /var/www/owncloud/lib/private/Console/Application.php(161): Symfony\Component\Console\Application->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#24 /var/www/owncloud/console.php(106): OC\Console\Application->run()
#25 /var/www/owncloud/occ(11): require_once(’/var/www/ownclo…’)
#26 {main}
| Folders | Files | Elapsed time | Items per second |
| 15 | 613 | 00:00:06 | 100 |
Debian
Apache
mysql
PHP 7.0.33-0+deb9u3
10.1.0.4
fresh install
02/2019
“system”: {
“instanceid”: “ocwtuadg09g1”,
“trusted_domains”: [
“owncloud.**.fr"
“datadirectory”: “/var/www/owncloud/data”,
“overwrite.cli.url”: "https://owncloud..fr/owncloud”,
“dbtype”: “mysql”,
“version”: “10.1.0.4”,
“dbname”: “owncloud”,
“dbhost”: “localhost”,
“dbtableprefix”: “oc_”,
“logtimezone”: “UTC”,
“installed”: true,
“force ssl”: true,
“loglevel”: 2,
“maintenance”: false,
“singleuser”: false
**List of activated apps:**
Enabled:
- comments: 0.3.0
- configreport: 0.1.1
- dav: 0.4.0
- federatedfilesharing: 0.3.1
- federation: 0.1.0
- files: 1.5.1
- files_external: 0.7.1
- files_external_ftp: 0.2.1
- files_sharing: 0.11.0
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- files_videoplayer: 0.9.8
- firstrunwizard: 1.1
- market: 0.3.0
- notifications: 0.4.1
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- templateeditor: 0.4.0
- updatenotification: 0.2.1
Disabled:
- encryption
- external
- user_external
FTP
NO
NO
SELECT * FROM oc_appconfig
WHERE appid
= ‘user_ldap’;
### Client configuration
**Browser:**
**Operating system:**
### Logs
#### Web server error log
I show a little part of the log beacose is too big
{“reqId”:“eedb03b6-f3fe-46a3-8e87-862a243b48ef”,“level”:3,“time”:“2019-03-21T13:41:04+00:00”,“remoteAddr”:“192.168.1.254”,“user”:“dlt”,“app”:“PHP”,“method”:“PROPFIND”,“url”:"/remote.php/dav/files/dlt/TSE_DLT/Mod%C3%A8les%20Office%20personnalis%C3%A9s",“message”:“Undefined offset: 7 at /var/www/owncloud/apps/files_external_ftp/lib/Storage/Adapter.php#44”}
{“reqId”:“eedb03b6-f3fe-46a3-8e87-862a243b48ef”,“level”:3,“time”:“2019-03-21T13:41:04+00:00”,“remoteAddr”:“192.168.1.254”,“user”:“dlt”,“app”:“PHP”,“method”:“PROPFIND”,“url”:"/remote.php/dav/files/dlt/TSE_DLT/Mod%C3%A8les%20Office%20personnalis%C3%A9s",“message”:“Undefined offset: 8 at /var/www/owncloud/apps/files_external_ftp/lib/Storage/Adapter.php#44”}
{“reqId”:“eedb03b6-f3fe-46a3-8e87-862a243b48ef”,“level”:3,“time”:“2019-03-21T13:41:04+00:00”,“remoteAddr”:“192.168.1.254”,“user”:“dlt”,“app”:“PHP”,“method”:“PROPFIND”,“url”:"/remote.php/dav/files/dlt/TSE_DLT/Mod%C3%A8les%20Office%20personnalis%C3%A9s",“message”:“Undefined offset: 0 at /var/www/owncloud/apps/files_external_ftp/lib/Storage/FTP.php#98”}
{“reqId”:“eedb03b6-f3fe-46a3-8e87-862a243b48ef”,“level”:3,“time”:“2019-03-21T13:41:04+00:00”,“remoteAddr”:“192.168.1.254”,“user”:“dlt”,“app”:“PHP”,“method”:“PROPFIND”,“url”:"/remote.php/dav/files/dlt/TSE_DLT/Mod%C3%A8les%20Office%20personnalis%C3%A9s",“message”:“Undefined offset: 4 at /var/www/owncloud/apps/files_external_ftp/lib/Storage/Adapter.php#44”}
{“reqId”:“eedb03b6-f3fe-46a3-8e87-862a243b48ef”,“level”:3,“time”:“2019-03-21T13:41:04+00:00”,“remoteAddr”:“192.168.1.254”,“user”:“dlt”,“app”:“PHP”,“method”:“PROPFIND”,“url”:"/remote.php/dav/files/dlt/TSE_DLT/Mod%C3%A8les%20Office%20personnalis%C3%A9s",“message”:“Undefined offset: 5 at /var/www/owncloud/apps/files_external_ftp/lib/Storage/Adapter.php#44”}
{“reqId”:“eedb03b6-f3fe-46a3-8e87-862a243b48ef”,“level”:3,“time”:“2019-03-21T13:41:04+00:00”,“remoteAddr”:“192.168.1.254”,“user”:“dlt”,“app”:“PHP”,“method”:“PROPFIND”,“url”:"/remote.php/dav/files/dlt/TSE_DLT/Mod%C3%A8les%20Office%20personnalis%C3%A9s",“message”:“Undefined offset: 6 at /var/www/owncloud/apps/files_external_ftp/lib/Storage/Adapter.php#44”}
#### Browser log
c) …
