Dear all,
After the last OC 8.1.6 update I have an issue with accessing the SQLite3 database.
This is the follow-up of topic “1091 Can’t DROP ‘PRIMARY’ with upgrade 8.1.6->8.1.9”.
Linked to GitHub issue #25663
- There had been an automatic update via /repositories/isv:/ownCloud:/community/xUbuntu_14.04 - openSUSE Download .
- In the same run of Ubuntu upgrade with the automatic owncloud update also mysql and php might have been updated.
- I do not think that the database has been corrupted, as I get the same failure scenario with owncloud.db backups which had been saved one month earlier (when owncloud was running fine). But somehow the connection between OC and the database could be lost.
- I checked /etc/php/php5.6/mods-available/pdo_sqlite.ini and sqlite3.ini, and both point to valid copies of their corresponding .so-files. Also, both are linked/activated in apache2/conf.d.
OC starting and accessing its database.
- OC wants to update himself without me having initiated an update. Update fails with error message:
Interner Serverfehler
Der Server hat einen internen Fehler und konnte Ihre Anfrage nicht vervollständigen.
Bitte wende Dich an den Serveradministrator, sollte dieser Fehler mehrfach auftreten, und füge Deiner Anfrage die unten stehenden technischen Details bei.
Weitere Details können im Serverprotokoll gefunden werden.
Technische Details
Entfernte Adresse: 192.168.1.22 Anforderungskennung: 6RVAhYb8UueVP44tC2A8 Typ: Doctrine\DBAL\DBALException Code: 0 Nachricht: Failed to connect to the database: An exception occurred while executing 'PRAGMA journal_mode = WAL': SQLSTATE[HY000]: General error: 11 database disk image is malformed Datei: /var/www/owncloud2/lib/private/db/connection.php Zeile: 50
Spur
#0 /var/www/owncloud2/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(973): OC\DB\Connection->connect() #1 /var/www/owncloud2/lib/private/db/connection.php(151): Doctrine\DBAL\Connection->executeUpdate('PRAGMA read_unc...', Array, Array) #2 /var/www/owncloud2/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(621): OC\DB\Connection->executeUpdate('PRAGMA read_unc...') #3 /var/www/owncloud2/lib/private/db/connection.php(83): Doctrine\DBAL\Connection->setTransactionIsolation(2) #4 /var/www/owncloud2/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\DB\Connection->__construct(Array, Object(Doctrine\DBAL\Driver\PDOSqlite\Driver), Object(Doctrine\DBAL\Configuration), Object(Doctrine\Common\EventManager)) #5 /var/www/owncloud2/lib/private/db/connectionfactory.php(124): Doctrine\DBAL\DriverManager::getConnection(Array, Object(Doctrine\DBAL\Configuration), Object(Doctrine\Common\EventManager)) #6 /var/www/owncloud2/lib/private/server.php(302): OC\DB\ConnectionFactory->getConnection('sqlite3', Array) #7 /var/www/owncloud2/3rdparty/pimple/pimple/src/Pimple/Container.php(112): OC\Server->OC\{closure}(Object(OC\Server)) #8 /var/www/owncloud2/lib/private/appframework/utility/simplecontainer.php(96): Pimple\Container->offsetGet('DatabaseConnect...') #9 /var/www/owncloud2/lib/private/server.php(697): OC\AppFramework\Utility\SimpleContainer->query('DatabaseConnect...') #10 /var/www/owncloud2/lib/private/db.php(42): OC\Server->getDatabaseConnection() #11 /var/www/owncloud2/lib/private/server.php(209): OC_DB::getConnection() #12 /var/www/owncloud2/3rdparty/pimple/pimple/src/Pimple/Container.php(112): OC\Server->OC\{closure}(Object(OC\Server)) #13 /var/www/owncloud2/lib/private/appframework/utility/simplecontainer.php(96): Pimple\Container->offsetGet('AppConfig') #14 /var/www/owncloud2/lib/private/server.php(643): OC\AppFramework\Utility\SimpleContainer->query('AppConfig') #15 /var/www/owncloud2/lib/private/server.php(344): OC\Server->getAppConfig() #16 /var/www/owncloud2/3rdparty/pimple/pimple/src/Pimple/Container.php(112): OC\Server->OC\{closure}(Object(OC\Server)) #17 /var/www/owncloud2/lib/private/appframework/utility/simplecontainer.php(96): Pimple\Container->offsetGet('AppManager') #18 /var/www/owncloud2/lib/private/server.php(863): OC\AppFramework\Utility\SimpleContainer->query('AppManager') #19 /var/www/owncloud2/lib/private/app.php(238): OC\Server->getAppManager() #20 /var/www/owncloud2/lib/private/app.php(93): OC_App::getEnabledApps() #21 /var/www/owncloud2/lib/base.php(592): OC_App::loadApps(Array) #22 /var/www/owncloud2/lib/base.php(1125): OC::init() #23 /var/www/owncloud2/index.php(46): require_once('/var/www/ownclo...') #24 {main}
- OC cannot access its database, e.g.
occ -Vgives …
Technische Details
Code: 0
Nachricht: Failed to connect to the database: An exception occurred while executing ‘PRAGMA journal_mode = WAL’: SQLSTATE[HY000]: General error: 11 database disk image is malformed
Zeile: 50
Spur
#1 /var/www/owncloud2/lib/private/db/connection.php(151): Doctrine\DBAL\Connection->executeUpdate(‘PRAGMA read_unc…’, Array, Array)
#2 /var/www/owncloud2/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(621): OC\DB\Connection->executeUpdate(‘PRAGMA read_unc…’)
#6 /var/www/owncloud2/lib/private/server.php(302): OC\DB\ConnectionFactory->getConnection(‘sqlite3’, Array)
#7 /var/www/owncloud2/3rdparty/pimple/pimple/src/Pimple/Container.php(112): OC\Server->OC{closure}(Object(OC\Server))
#8 /var/www/owncloud2/lib/private/appframework/utility/simplecontainer.php(96): Pimple\Container->offsetGet(‘DatabaseConnect…’)
#9 /var/www/owncloud2/lib/private/server.php(697): OC\AppFramework\Utility\SimpleContainer->query(‘DatabaseConnect…’)
#12 /var/www/owncloud2/3rdparty/pimple/pimple/src/Pimple/Container.php(112): OC\Server->OC{closure}(Object(OC\Server))
#13 /var/www/owncloud2/lib/private/appframework/utility/simplecontainer.php(96): Pimple\Container->offsetGet(‘AppConfig’)
#14 /var/www/owncloud2/lib/private/server.php(643): OC\AppFramework\Utility\SimpleContainer->query(‘AppConfig’)
#16 /var/www/owncloud2/3rdparty/pimple/pimple/src/Pimple/Container.php(112): OC\Server->OC{closure}(Object(OC\Server))
#17 /var/www/owncloud2/lib/private/appframework/utility/simplecontainer.php(96): Pimple\Container->offsetGet(‘AppManager’)
#18 /var/www/owncloud2/lib/private/server.php(863): OC\AppFramework\Utility\SimpleContainer->query(‘AppManager’)
#23 /var/www/owncloud2/index.php(46): require_once(‘/var/www/ownclo…’)
#24 {main}
Operating system: Ubuntu 14.04.1
Web server: apache2
Database: Mysql 5.5.50, SQLite 3.8.2
PHP version: 5.6
ownCloud version: 8.1.6
Updated from an older ownCloud or fresh install: continuously updated since v6 via SUSE repos /repositories/isv:/ownCloud:/community/xUbuntu_14.04 - openSUSE Download
config.php:
<?php $CONFIG = array ( 'instanceid' => 'oc3a41047555', 'passwordsalt' => '3ee12637fa36136a5e3cbe60433a1f', 'datadirectory' => '/var/www/owncloud/data', 'dbtype' => 'sqlite3', 'dbname' => 'ownclouddb', 'dbhost' => 'localhost', 'version' => '8.1.6.2', 'installed' => true, 'forcessl' => true, 'theme' => '', 'maintenance' => false, 'trusted_domains' => array ( 0 => '192.168.1.24', 1 => 'localhost', 2 => 'home.mydomain.de', ), 'forceSSLforSubdomains' => true, 'appcodechecker' => false, 'xframe_restriction' => false, 'cache_path' => '', 'quota_include_external_storage' => false, 'filesystem_check_changes' => 0, 'appstore.experimental.enabled' => false, 'updatechecker' => false, );
“reqId”:“cEUEF/se7gNzvxRzJsoP”,“remoteAddr”:“212.27.185.253”,“app”:“index”,“message”:"Exception: {"Exception":"Doctrine$
“reqId”:“vjQFGf15JZlPq+dVD1yT”,“remoteAddr”:“212.27.185.253”,“app”:“index”,“message”:"Exception: {"Exception":"Doctrine\$
{“reqId”:“SithAJT107BsSi3u6wRH”,“remoteAddr”:“192.168.1.22”,“app”:“index”,“message”:"Exception: {"Exception":"Doctrine\\$
Best regards
Chris
