Overlays / Status should update itself
There are no overlays over the icons like there used to be.
But there are static blue circle arrows next to the filename in list view (all of them static blue arrows. no checkmarks or other icons)
When I hover over them I get a message at the bottom of explorer saying “Status: synchronization pending”
But I can see in the OC Client that the files sync as they should - it’s just not shown in those explorer status icons.
I had connection problems so I unistalled V 2.9.x and the Explorer Items remained. I then cleaned everything and they might have been gone in the meantime or not. Don’t remember. Installed, different V2.9x and uninstalled and solved connection problems. Now V2.10.
I would not mind the overlay symbols being on the side instead of on top of the item. And I could live with them just being wrong.
But the problem is, when I now try to delete any of these folders, Win 10 says “can’t delete, because synching has not finished”
I registered OCOverlays.dll manually with regsrv32, but that did not change anything.
Looks like the connection between OC and Explorer is broken somewhere
Operating system: Win 10
ownCloud version:10.1
Client version: 2.10
OS language: German
Installation path of client:
logs.
Client logfile: Output of
owncloud --logwindow
orowncloud --logfile log.txt
(On Windows usingcmd.exe
, you might need to firstcd
into the ownCloud directory)
(See also Redirect Notice ) -
Web server error log:
