Hi Everyone!
I think I need some help on this. I have read most everything I can and still cannot come up with a solution.
Thanks in advance for any insight or suggestions!
Paul.
- We have a 9.1 install on an Ubuntu VM in Hyper-V
- We have several SMB external shares
- When users browse the share via the Web or Client there are files and folders missing.
- If I manually create a folder at the same level as the missing items, they appear.
- I did run through and fixed any read only items .
Operating system: U 16.04
Web server: Apache
ownCloud version: 9.1
Updated from an older ownCloud or fresh install: Fresh
ownCloud log: the log was too large, I have reset it.
External Storage to SMB (Windows 10) shares on host for this VM
No errors for integrity
Log:
{“reqId”:“a523uLo+zymIzMzBltj8”,“remoteAddr”:“”,“app”:“files”,“message”:“Exception: {"Exception":"Icewind\\SMB\\Exception\\Exception","Message":"Unknown error (NT_STATUS_OBJECT_NAME_INVALID)","Code":0,"Trace":"#0 \/var\/www\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/Share.php(398): Icewind\\SMB\\Parser->checkForError(Array, ‘’)\n#1 \/var\/www\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/Share.php(140): Icewind\\SMB\\Share->parseOutput(Array, ‘’)\n#2 \/var\/www\/owncloud\/apps\/files_external\/lib\/Lib\/Storage\/SMB.php(115): Icewind\\SMB\\Share->stat(‘’)\n#3 \/var\/www\/owncloud\/apps\/files_external\/lib\/Lib\/Storage\/SMB.php(385): OCA\\Files_External\\Lib\\Storage\\SMB->getFileInfo(‘’)\n#4 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Common.php(144): OCA\\Files_External\\Lib\\Storage\\SMB->isUpdatable(‘.’)\n#5 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Common.php(162): OC\\Files\\Storage\\Common->isDeletable(‘Zoning Bylaws’)\n#6 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Common.php(637): OC\\Files\\Storage\\Common->getPermissions(‘Zoning Bylaws’)\n#7 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Wrapper\/Wrapper.php(572): OC\\Files\\Storage\\Common->getMetaData(‘Zoning Bylaws’)\n#8 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Wrapper\/Wrapper.php(572): OC\\Files\\Storage\\Wrapper\\Wrapper->getMetaData(‘Zoning Bylaws’)\n#9 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Wrapper\/Availability.php(459): OC\\Files\\Storage\\Wrapper\\Wrapper->getMetaData(‘Zoning Bylaws’)\n#10 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Wrapper\/Encryption.php(172): OC\\Files\\Storage\\Wrapper\\Availability->getMetaData(‘Zoning Bylaws’)\n#11 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Wrapper\/Wrapper.php(572): OC\\Files\\Storage\\Wrapper\\Encryption->getMetaData(‘Zoning Bylaws’)\n#12 \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php(113): OC\\Files\\Storage\\Wrapper\\Wrapper->getMetaData(‘Zoning Bylaws’)\n#13 \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php(145): OC\\Files\\Cache\\Scanner->getData(‘Zoning Bylaws’)\n#14 \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php(309): OC\\Files\\Cache\\Scanner->scanFile(‘Zoning Bylaws’, 3, -1, NULL, true)\n#15 \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php(484): OC\\Files\\Cache\\Scanner->scan(‘Zoning Bylaws’, 2, 3)\n#16 \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php(495): OC\\Files\\Cache\\Scanner->OC\\Files\\Cache\\{closure}()\n#17 \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php(485): OC\\Files\\Cache\\Scanner->runBackgroundScanJob(Object(Closure), ‘Zoning Bylaws’)\n#18 \/var\/www\/owncloud\/lib\/private\/Files\/Utils\/Scanner.php(142): OC\\Files\\Cache\\Scanner->backgroundScan()\n#19 \/var\/www\/owncloud\/apps\/files\/lib\/BackgroundJob\/ScanFiles.php(87): OC\\Files\\Utils\\Scanner->backgroundScan(‘’)\n#20 \/var\/www\/owncloud\/apps\/files\/lib\/BackgroundJob\/ScanFiles.php(111): OCA\\Files\\BackgroundJob\\ScanFiles->runScanner(Object(OC\\User\\User))\n#21 \/var\/www\/owncloud\/lib\/private\/BackgroundJob\/Job.php(52): OCA\\Files\\BackgroundJob\\ScanFiles->run(NULL)\n#22 \/var\/www\/owncloud\/lib\/private\/BackgroundJob\/TimedJob.php(53): OC\\BackgroundJob\\Job->execute(Object(OC\\BackgroundJob\\JobList), Object(OC\\Log))\n#23 \/var\/www\/owncloud\/cron.php(122): OC\\BackgroundJob\\TimedJob->execute(Object(OC\\BackgroundJob\\JobList), Object(OC\\Log))\n#24 {main}","File":"\/var\/www\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/Parser.php","Line":74}”,“level”:3,“time”:“2016-08-28T14:00:03+00:00”,“method”:“–”,“url”:“–”,“user”:“–”}
{“reqId”:“a523uLo+zymIzMzBltj8”,“remoteAddr”:“”,“app”:“files”,“message”:“Exception: {"Exception":"Icewind\\SMB\\Exception\\Exception","Message":"Unknown error (NT_STATUS_OBJECT_NAME_INVALID)","Code":0,"Trace":"#0 \/var\/www\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/Share.php(398): Icewind\\SMB\\Parser->checkForError(Array, ‘’)\n#1 \/var\/www\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/Share.php(140): Icewind\\SMB\\Share->parseOutput(Array, ‘’)\n#2 \/var\/www\/owncloud\/apps\/files_external\/lib\/Lib\/Storage\/SMB.php(115): Icewind\\SMB\\Share->stat(‘’)\n#3 \/var\/www\/owncloud\/apps\/files_external\/lib\/Lib\/Storage\/SMB.php(385): OCA\\Files_External\\Lib\\Storage\\SMB->getFileInfo(‘’)\n#4 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Common.php(144): OCA\\Files_External\\Lib\\Storage\\SMB->isUpdatable(‘.’)\n#5 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Common.php(162): OC\\Files\\Storage\\Common->isDeletable(‘Menck’)\n#6 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Common.php(637): OC\\Files\\Storage\\Common->getPermissions(‘Menck’)\n#7 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Wrapper\/Wrapper.php(572): OC\\Files\\Storage\\Common->getMetaData(‘Menck’)\n#8 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Wrapper\/Wrapper.php(572): OC\\Files\\Storage\\Wrapper\\Wrapper->getMetaData(‘Menck’)\n#9 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Wrapper\/Availability.php(459): OC\\Files\\Storage\\Wrapper\\Wrapper->getMetaData(‘Menck’)\n#10 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Wrapper\/Encryption.php(172): OC\\Files\\Storage\\Wrapper\\Availability->getMetaData(‘Menck’)\n#11 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Wrapper\/Wrapper.php(572): OC\\Files\\Storage\\Wrapper\\Encryption->getMetaData(‘Menck’)\n#12 \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php(113): OC\\Files\\Storage\\Wrapper\\Wrapper->getMetaData(‘Menck’)\n#13 \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php(145): OC\\Files\\Cache\\Scanner->getData(‘Menck’)\n#14 \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php(309): OC\\Files\\Cache\\Scanner->scanFile(‘Menck’, 3, -1, NULL, true)\n#15 \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php(484): OC\\Files\\Cache\\Scanner->scan(‘Menck’, 2, 3)\n#16 \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php(495): OC\\Files\\Cache\\Scanner->OC\\Files\\Cache\\{closure}()\n#17 \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php(485): OC\\Files\\Cache\\Scanner->runBackgroundScanJob(Object(Closure), ‘Menck’)\n#18 \/var\/www\/owncloud\/lib\/private\/Files\/Utils\/Scanner.php(142): OC\\Files\\Cache\\Scanner->backgroundScan()\n#19 \/var\/www\/owncloud\/apps\/files\/lib\/BackgroundJob\/ScanFiles.php(87): OC\\Files\\Utils\\Scanner->backgroundScan(‘’)\n#20 \/var\/www\/owncloud\/apps\/files\/lib\/BackgroundJob\/ScanFiles.php(111): OCA\\Files\\BackgroundJob\\ScanFiles->runScanner(Object(OC\\User\\User))\n#21 \/var\/www\/owncloud\/lib\/private\/BackgroundJob\/Job.php(52): OCA\\Files\\BackgroundJob\\ScanFiles->run(NULL)\n#22 \/var\/www\/owncloud\/lib\/private\/BackgroundJob\/TimedJob.php(53): OC\\BackgroundJob\\Job->execute(Object(OC\\BackgroundJob\\JobList), Object(OC\\Log))\n#23 \/var\/www\/owncloud\/cron.php(122): OC\\BackgroundJob\\TimedJob->execute(Object(OC\\BackgroundJob\\JobList), Object(OC\\Log))\n#24 {main}","File":"\/var\/www\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/Parser.php","Line":74}”,“level”:3,“time”:“2016-08-28T14:00:03+00:00”,“method”:“–”,“url”:“–”,“user”:“–”}
{“reqId”:“a523uLo+zymIzMzBltj8”,“remoteAddr”:“”,“app”:“files”,“message”:“Exception: {"Exception":"Icewind\\SMB\\Exception\\Exception","Message":"Unknown error (NT_STATUS_OBJECT_NAME_INVALID)","Code":0,"Trace":"#0 \/var\/www\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/Share.php(398): Icewind\\SMB\\Parser->checkForError(Array, ‘’)\n#1 \/var\/www\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/Share.php(140): Icewind\\SMB\\Share->parseOutput(Array, ‘’)\n#2 \/var\/www\/owncloud\/apps\/files_external\/lib\/Lib\/Storage\/SMB.php(115): Icewind\\SMB\\Share->stat(‘’)\n#3 \/var\/www\/owncloud\/apps\/files_external\/lib\/Lib\/Storage\/SMB.php(385): OCA\\Files_External\\Lib\\Storage\\SMB->getFileInfo(‘’)\n#4 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Common.php(144): OCA\\Files_External\\Lib\\Storage\\SMB->isUpdatable(‘.’)\n#5 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Common.php(162): OC\\Files\\Storage\\Common->isDeletable(‘Windrush’)\n#6 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Common.php(637): OC\\Files\\Storage\\Common->getPermissions(‘Windrush’)\n#7 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Wrapper\/Wrapper.php(572): OC\\Files\\Storage\\Common->getMetaData(‘Windrush’)\n#8 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Wrapper\/Wrapper.php(572): OC\\Files\\Storage\\Wrapper\\Wrapper->getMetaData(‘Windrush’)\n#9 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Wrapper\/Availability.php(459): OC\\Files\\Storage\\Wrapper\\Wrapper->getMetaData(‘Windrush’)\n#10 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Wrapper\/Encryption.php(172): OC\\Files\\Storage\\Wrapper\\Availability->getMetaData(‘Windrush’)\n#11 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Wrapper\/Wrapper.php(572): OC\\Files\\Storage\\Wrapper\\Encryption->getMetaData(‘Windrush’)\n#12 \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php(113): OC\\Files\\Storage\\Wrapper\\Wrapper->getMetaData(‘Windrush’)\n#13 \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php(145): OC\\Files\\Cache\\Scanner->getData(‘Windrush’)\n#14 \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php(309): OC\\Files\\Cache\\Scanner->scanFile(‘Windrush’, 3, -1, NULL, true)\n#15 \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php(484): OC\\Files\\Cache\\Scanner->scan(‘Windrush’, 2, 3)\n#16 \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php(495): OC\\Files\\Cache\\Scanner->OC\\Files\\Cache\\{closure}()\n#17 \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php(485): OC\\Files\\Cache\\Scanner->runBackgroundScanJob(Object(Closure), ‘Windrush’)\n#18 \/var\/www\/owncloud\/lib\/private\/Files\/Utils\/Scanner.php(142): OC\\Files\\Cache\\Scanner->backgroundScan()\n#19 \/var\/www\/owncloud\/apps\/files\/lib\/BackgroundJob\/ScanFiles.php(87): OC\\Files\\Utils\\Scanner->backgroundScan(‘’)\n#20 \/var\/www\/owncloud\/apps\/files\/lib\/BackgroundJob\/ScanFiles.php(111): OCA\\Files\\BackgroundJob\\ScanFiles->runScanner(Object(OC\\User\\User))\n#21 \/var\/www\/owncloud\/lib\/private\/BackgroundJob\/Job.php(52): OCA\\Files\\BackgroundJob\\ScanFiles->run(NULL)\n#22 \/var\/www\/owncloud\/lib\/private\/BackgroundJob\/TimedJob.php(53): OC\\BackgroundJob\\Job->execute(Object(OC\\BackgroundJob\\JobList), Object(OC\\Log))\n#23 \/var\/www\/owncloud\/cron.php(122): OC\\BackgroundJob\\TimedJob->execute(Object(OC\\BackgroundJob\\JobList), Object(OC\\Log))\n#24 {main}","File":"\/var\/www\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/Parser.php","Line":74}”,“level”:3,“time”:“2016-08-28T14:00:03+00:00”,“method”:“–”,“url”:“–”,“user”:“–”}
{“reqId”:“a523uLo+zymIzMzBltj8”,“remoteAddr”:“”,“app”:“files”,“message”:“Exception: {"Exception":"Icewind\\SMB\\Exception\\Exception","Message":"Unknown error (NT_STATUS_OBJECT_NAME_INVALID)","Code":0,"Trace":"#0 \/var\/www\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/Share.php(398): Icewind\\SMB\\Parser->checkForError(Array, ‘’)\n#1 \/var\/www\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/Share.php(140): Icewind\\SMB\\Share->parseOutput(Array, ‘’)\n#2 \/var\/www\/owncloud\/apps\/files_external\/lib\/Lib\/Storage\/SMB.php(115): Icewind\\SMB\\Share->stat(‘’)\n#3 \/var\/www\/owncloud\/apps\/files_external\/lib\/Lib\/Storage\/SMB.php(385): OCA\\Files_External\\Lib\\Storage\\SMB->getFileInfo(‘’)\n#4 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Common.php(144): OCA\\Files_External\\Lib\\Storage\\SMB->isUpdatable(‘.’)\n#5 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Common.php(162): OC\\Files\\Storage\\Common->isDeletable(‘Inactive Client…’)\n#6 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Common.php(637): OC\\Files\\Storage\\Common->getPermissions(‘Inactive Client…’)\n#7 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Wrapper\/Wrapper.php(572): OC\\Files\\Storage\\Common->getMetaData(‘Inactive Client…’)\n#8 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Wrapper\/Wrapper.php(572): OC\\Files\\Storage\\Wrapper\\Wrapper->getMetaData(‘Inactive Client…’)\n#9 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Wrapper\/Availability.php(459): OC\\Files\\Storage\\Wrapper\\Wrapper->getMetaData(‘Inactive Client…’)\n#10 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Wrapper\/Encryption.php(172): OC\\Files\\Storage\\Wrapper\\Availability->getMetaData(‘Inactive Client…’)\n#11 \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Wrapper\/Wrapper.php(572): OC\\Files\\Storage\\Wrapper\\Encryption->getMetaData(‘Inactive Client…’)\n#12 \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php(113): OC\\Files\\Storage\\Wrapper\\Wrapper->getMetaData(‘Inactive Client…’)\n#13 \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php(145): OC\\Files\\Cache\\Scanner->getData(‘Inactive Client…’)\n#14 \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php(309): OC\\Files\\Cache\\Scanner->scanFile(‘Inactive Client…’, 3, -1, NULL, true)\n#15 \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php(484): OC\\Files\\Cache\\Scanner->scan(‘Inactive Client…’, 2, 3)\n#16 \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php(495): OC\\Files\\Cache\\Scanner->OC\\Files\\Cache\\{closure}()\n#17 \/var\/www\/owncloud\/lib\/private\/Files\/Cache\/Scanner.php(485): OC\\Files\\Cache\\Scanner->runBackgroundScanJob(Object(Closure), ‘Inactive Client…’)\n#18 \/var\/www\/owncloud\/lib\/private\/Files\/Utils\/Scanner.php(142): OC\\Files\\Cache\\Scanner->backgroundScan()\n#19 \/var\/www\/owncloud\/apps\/files\/lib\/BackgroundJob\/ScanFiles.php(87): OC\\Files\\Utils\\Scanner->backgroundScan(‘’)\n#20 \/var\/www\/owncloud\/apps\/files\/lib\/BackgroundJob\/ScanFiles.php(111): OCA\\Files\\BackgroundJob\\ScanFiles->runScanner(Object(OC\\User\\User))\n#21 \/var\/www\/owncloud\/lib\/private\/BackgroundJob\/Job.php(52): OCA\\Files\\BackgroundJob\\ScanFiles->run(NULL)\n#22 \/var\/www\/owncloud\/lib\/private\/BackgroundJob\/TimedJob.php(53): OC\\BackgroundJob\\Job->execute(Object(OC\\BackgroundJob\\JobList), Object(OC\\Log))\n#23 \/var\/www\/owncloud\/cron.php(122): OC\\BackgroundJob\\TimedJob->execute(Object(OC\\BackgroundJob\\JobList), Object(OC\\Log))\n#24 {main}","File":"\/var\/www\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/Parser.php","Line":74}”,“level”:3,“time”:“2016-08-28T14:00:03+00:00”,“method”:“–”,“url”:“–”,“user”:“–”}
