Using 10.0.8.
I would like to add external storage via FTP but I only have:
I didn’t find any info about FTP being removed and/or how to enable it.
Can someone please help me?
This links tells it should be there… ownCloud Documentation Overview
Using 10.0.8.
Hey, i think you need to install the following app via the marketplace from within ownCloud:
Thank you Tom, the app should do what I need.
As a non-hardcore OC user, I found some problems I would like to share with OC community about this topic:
Lack of documentation (or even worse, broken) is the first thing that makes users say “this doesn’t work”.
And, I write it here because I found no other place to write it, I found a bug in the plugin: it does not consider the timezone difference between the server running OC and the remote FTP, so it says it was updated X hours ahead of now, in my case 2, because we’re on a 2 hour tz difference. This is an obvious case to spot, but I suppose it will be a problem with file information (think a about log files)
Hey, from what i know you can post issues with the documentation at https://github.com/owncloud/documentation/issues. I havn’t tried this on my own but from a short look it seems that the people maintaining the documentation are quite responsive there.
The plugin itself seems to have an own issue tracker at https://github.com/owncloud/files_external_ftp/issues.
I think its probably the best to report the issues you’re facing over there. My own experience has shown that posting issues or bugs in a user support forum like the forum here are often / mostly getting lost.
Done both, thanks you for the precious help, it samed me a lot of time!
Nice, i think its always great that users like us are giving feedback to documentation writers or developers like this.
