External smb storage fails
I have, otherwise fully OK samba, but my owncload cannot get to it.
As an external storage smb I choose “Log-in credentials”
On my setup(pretty default) users log into owncloud with an ldap backend, the very same samba uses, yet in samba logs I see:
2017/10/05 15:41:00.479585, 5] ../source3/auth/server_info_sam.c:122(make_server_info_sam)
make_server_info_sam: made server info for user cloudadmin → cloudadmin
[2017/10/05 15:41:00.479709, 3] ../source3/auth/auth.c:249(auth_check_ntlm_password)
check_ntlm_password: sam authentication for user [cloudadmin] succeeded
[2017/10/05 15:41:00.479772, 5] ../source3/auth/auth.c:292(auth_check_ntlm_password)
check_ntlm_password: PAM Account for user [cloudadmin] succeeded
[2017/10/05 15:41:00.479810, 2] ../source3/auth/auth.c:305(auth_check_ntlm_password)
check_ntlm_password: authentication for user [cloudadmin] → [cloudadmin] → [cloudadmin] succeeded
[2017/10/05 15:41:00.481148, 2] ../source3/passdb/pdb_ldap.c:2310(init_group_from_ldap)
init_group_from_ldap: Entry found for group: 544
[2017/10/05 15:41:00.481740, 4] ../source3/passdb/pdb_ldap.c:2437(ldapsam_getgroup)
ldapsam_getgroup: Did not find group, filter was (&(objectClass=sambaGroupMapping)(sambaSID=S-1-5-32-545))
[2017/10/05 15:41:00.482335, 4] ../source3/passdb/pdb_ldap.c:2437(ldapsam_getgroup)
[2017/10/05 15:41:00.484920, 4] ../source3/passdb/pdb_ldap.c:2437(ldapsam_getgroup)
ldapsam_getgroup: Did not find group, filter was (&(objectClass=sambaGroupMapping)(sambaSID=S-1-1-0))
[2017/10/05 15:41:00.485371, 4] ../source3/passdb/pdb_ldap.c:2437(ldapsam_getgroup)
[2017/10/05 15:41:00.485723, 4] ../source3/passdb/pdb_ldap.c:2437(ldapsam_getgroup)
ldapsam_getgroup: Did not find group, filter was (&(objectClass=sambaGroupMapping)(sambaSID=S-1-5-2))
[2017/10/05 15:41:00.486136, 4] ../source3/passdb/pdb_ldap.c:2437(ldapsam_getgroup)
[2017/10/05 15:41:00.486525, 4] ../source3/passdb/pdb_ldap.c:2437(ldapsam_getgroup)
ldapsam_getgroup: Did not find group, filter was (&(objectClass=sambaGroupMapping)(sambaSID=S-1-5-11))
[2017/10/05 15:41:00.486979, 4] ../source3/passdb/pdb_ldap.c:2437(ldapsam_getgroup)
Centos 7.4
Apache
owncloud-9.1.5-1.el7.noarch
php-smbclient-0.9.0-1.el7.x86_64
samba-4.6.2-11.el7_4.x86_64
Hey there,
did you have a look at our documentation? Maybe you missed something in your configuration
https://doc.owncloud.com/server/10.0/admin_manual/enterprise/external_storage/windows-network-drive_configuration.html?highlight=wnd
