External storage does not work (dropbox + webdav)
1Upgrade from owncloud 9 to 10. I already had dropbox external storage that I added on my server and a webdaw on my personal computer which is on debian.
The external storages should remain connected as it was under owncloud 9.
The external storages are not connected. I get this message for dropbox when I connect to owncloud with my browser:
Dropbox API rate limit exceeded. Do you want to review mount point config in admin settings page?
On my personal computer, the webdav sharing does not work anymore. I connected my owncloud account with gnome. It is how I was connected to my cloud with webdav. When I click on the tab of my cloud on my personal computer which is on debian 9, I get this message (I translated it from French to English):
Impossible to access to “user_name@cloud_dns”
This share does not support WebDav
Debian GNU/Linux 9.3 (stretch)
Apache/2.4.25 (Debian)
PHP 7.0.19-1
10.0.4.4
owncloud 9
debian stretch backports
No errors have been found
    "system": {
        "updatechecker": false,
        "instanceid": "octg8xzbc7wj",
        "trusted_domains": [
            "IP of the server",
            "cloud dns"
        "overwrite.cli.url": "http:\/\/cloud.debian-economist.eu",
        "dbtype": "mysql",
        "version": "10.0.4.4",
        "dbname": "owncloud",
        "dbhost": "localhost",
        "dbtableprefix": "oc_",
        "logtimezone": "UTC",
        "installed": true,
        "maintenance": false,
        "loglevel": 2,
        "debug": false
Enabled:
  - activity: 2.3.6
  - audioplayer: 2.2.1
  - bookmarks: 0.10.2
  - calendar: 1.5.4
  - comments: 0.3.0
  - configreport: 0.1.1
  - contacts: 1.5.3
  - customgroups: 0.3.5
  - dav: 0.3.2
  - diagnostics: 0.1.2
  - encryption: 1.3.1
  - external: true
  - federatedfilesharing: 0.3.1
  - federation: 0.1.0
  - files: 1.5.1
  - files_antivirus: 0.11.2
  - files_clipboard: 0.6.2
  - files_external: 0.7.1
  - files_external_dropbox: 1.0.0
  - files_external_ftp: 0.2.0
  - files_pdfviewer: 0.8.2
  - files_sharing: 0.10.1
  - files_texteditor: 2.2.1
  - files_trashbin: 0.9.1
  - files_versions: 1.3.0
  - files_videoplayer: 0.9.8
  - firstrunwizard: 1.1
  - gallery: 16.0.2
  - gpxedit: 0.0.7
  - gpxmotion: 0.0.5
  - gpxpod: 2.2.1
  - guests: 0.5.0
  - market: 0.2.3
  - music: 0.5.5
  - notifications: 0.3.2
  - ownbackup: 17.7.0
  - phonetrack: 0.0.8
  - provisioning_api: 0.5.0
  - richdocuments: 1.1.27
  - security: 0.0.2
  - systemtags: 0.3.0
  - tasks: 0.9.3
  - templateeditor: 0.1
  - theme-example: 1.0.0
  - updatenotification: 0.2.1
  - user_external: 0.4
  - user_ldap: 0.9.1
  - xmas: 0.0.3
Are you using external storage, if yes which one: dropbox
Are you using encryption: yes
Are you using an external user-backend, if yes which one: WebDav (on my personal computer)
Debian 9.3 Stretch
{"reqId":"NjHX8bGdyuuyjRfDbf7Z","level":3,"time":"2017-12-13T14:11:27+00:00","remoteAddr":"IP of my personal computer","user":"tchokapix","app":"PHP","method":"GET","url":"\/ocs\/v2.php\/ap\
ps\/notifications\/api\/v1\/notifications?format=json","message":"You are using a fallback implementation of the intl extension. Installing the native one is highly recommende\
d instead. at \/var\/www\/owncloud\/lib\/composer\/patchwork\/utf8\/src\/Patchwork\/Utf8\/Bootup\/intl.php#18"}
So my server gets the request of my personal computer. I installed php7.0-intl on the server but I have still the same issues.
