- Storage type Local option is not showing u
Should see Local in the drop down
Local is missing
Raspberry Pi 4Stock Raspbian linu
Apache2
Mariadb
PHP 7.3
installed | 1 |
maintenance | |
needsDbUpgrade | |
version | 10.6.0.5 |
versionstring | 10.6.0 |
edition | Community |
productname | ownCloud |
hostname | raspberrypi |
no
from owncloud webpage
<<<< NEW USER UNABLE TO ATTACH FILES>>>>
Are you using external storage, if yes which one: local/smb/sftp/âŚ
Are you using an external user-backend, if yes which one: LDAP/ActiveDirectory/Webdav/âŚ
