External Storage - No Text Input Fields for entering Folder, etc
  1. Activated External Storage App
  2. Went to External Storage Settings (in Personal Section)
Want to enter Folder Name and type of External Storage.
No Text Input fields or Drop Down Menu visible.
(This is how it looks like: https://s15.postimg.io/3mrt7njd7/Bildschirmfoto_2016_09_18_um_09_51_11.png)
Using Public host, don’t have much information on my fingertips.
Operating system: Linux www5 3.16-2-amd64 #1 SMP Debian 3.16.3-2 (2014-09-20) x86_64
Database: MySQL 5.5.50
PHP version: 5.6.24
No enteries from today in log file. (Since today I’m working on this).
server-side-encryption enabled
Integrity status for oC9+
Why are those input fields invisible and how can I make them visible?
Thanks,
Lukas
You need to enable the storages within your admin backend (See ownCloud Documentation Overview) for a specific user or group before these users or groups can use them.
Oh, thank you, that’s it. It works now.
Didn’t figure out that there was a separate Setting section for this.
I’m also having this same issue. It must be staring at me in the face but I can’t for the life of me find in the manual linked where to enable the storages.
I’ve enabled the ES App. I’m on ownCloud 9.1 on Ubuntu. PHP 7.
Same issue here… people keep saying the same thing. You enable it in the back end via the app but that does nothing, there is no drop down list under personal settings. I can see the storage option but cannot add anything to it. Please help, this is most frustrating.
Please do not just keep linking back to the guide, I’ve followed the guide to a tee and it does not explain what the problem is. A screenshot would be extremely helpful here.
Cheers.
There is a option “Allow users to mount external storage” in your admin backend which needs to be enabled…
