- enable external storage app
- try to connect to a samba share
- show files of the samba share
I get the green dot in the admin page and the samba share appears in my file list but I get the error “Storage not available”
Operating system: debian 7.11
Web server: apache 2.2
Database: mysql 5.5.54
PHP version: 5.4.45
ownCloud version: 9.0.3
Updated from an older ownCloud or fresh install: update
Special configuration: external sotrage
{"reqId":"j+Uh60hC\/KtL0OSAzdm\/","remoteAddr":"62.94.229.113","app":"files_external","message":"Exception: {\"Exception\":\"OCP\\\\Files\\\\StorageNotAvailableException\",\"Message\":\"Invalid hostname\",\"Code\":0,\"Trace\":\"#0 \\\/mnt\\\/owncloud_data\\\/cloud.caritasrovigo.org\\\/apps\\\/files_external\\\/lib\\\/smb.php(276): OC\\\\Files\\\\Storage\\\\SMB->getFileInfo('')\\n#1 \\\/mnt\\\/owncloud_data\\\/cloud.caritasrovigo.org\\\/lib\\\/private\\\/files\\\/storage\\\/common.php(434): OC\\\\Files\\\\Storage\\\\SMB->stat('')\\n#2 \\\/mnt\\\/owncloud_data\\\/cloud.caritasrovigo.org\\\/apps\\\/files_external\\\/lib\\\/smb.php(613): OC\\\\Files\\\\Storage\\\\Common->test()\\n#3 \\\/mnt\\\/owncloud_data\\\/cloud.caritasrovigo.org\\\/apps\\\/files_external\\\/lib\\\/config.php(231): OC\\\\Files\\\\Storage\\\\SMB->test(false, true)\\n#4 \\\/mnt\\\/owncloud_data\\\/cloud.caritasrovigo.org\\\/apps\\\/files_external\\\/controller\\\/storagescontroller.php(258): OC_Mount_Config::getBackendStatus('\\\\\\\\OC\\\\\\\\Files\\\\\\\\Stora...', Array, false, true)\\n#5 \\\/mnt\\\/owncloud_data\\\/cloud.caritasrovigo.org\\\/apps\\\/files_external\\\/controller\\\/globalstoragescontroller.php(181): OCA\\\\Files_External\\\\Controller\\\\StoragesController->updateStorageStatus(Object(OCA\\\\Files_external\\\\Lib\\\\StorageConfig), true)\\n#6 [internal function]: OCA\\\\Files_External\\\\Controller\\\\GlobalStoragesController->update(1, 'scancloud', 'smb', 'password::passw...', Array, Array, Array, Array, 100, true)\\n#7 \\\/mnt\\\/owncloud_data\\\/cloud.caritasrovigo.org\\\/lib\\\/private\\\/appframework\\\/http\\\/dispatcher.php(159): call_user_func_array(Array, Array)\\n#8 \\\/mnt\\\/owncloud_data\\\/cloud.caritasrovigo.org\\\/lib\\\/private\\\/appframework\\\/http\\\/dispatcher.php(89): OC\\\\AppFramework\\\\Http\\\\Dispatcher->executeController(Object(OCA\\\\Files_External\\\\Controller\\\\GlobalStoragesController), 'update')\\n#9 \\\/mnt\\\/owncloud_data\\\/cloud.caritasrovigo.org\\\/lib\\\/private\\\/appframework\\\/app.php(110): OC\\\\AppFramework\\\\Http\\\\Dispatcher->dispatch(Object)
Please paste possible errors in the following code block, see https://central.owncloud.org/t/how-to-find-webserver-or-oc-logfile-enable-php-logfile/808 for more info
Notice I installed php5-libsmcloud as suggested in the documentation.
I think this package is broken and the module isn’t enabled.
ls -l /etc/php5/mods-available/
totale 32
-rw-r--r-- 1 root root 68 gen 9 2015 curl.ini
-rw-r--r-- 1 root root 64 gen 9 2015 gd.ini
-rw-r--r-- 1 root root 84 gen 9 2015 intl.ini
lrwxrwxrwx 1 root root 45 feb 7 15:36 libsmbclient.ini -> /usr/share/php5/libsmbclient/libsmbclient.ini
-rw-r--r-- 1 root root 72 gen 9 2015 mcrypt.ini
-rw-r--r-- 1 root root 71 gen 9 2015 mysqli.ini
-rw-r--r-- 1 root root 70 gen 9 2015 mysql.ini
-rw-r--r-- 1 root root 66 gen 9 2015 pdo.ini
-rw-r--r-- 1 root root 74 gen 9 2015 pdo_mysql.ini
ls -l /usr/share/php5/libsmbclient/libsmbclient.ini
ls: impossibile accedere a /usr/share/php5/libsmbclient/libsmbclient.ini: File o directory non esistente
locate libsmbclient.ini
