I’m running OwnCloud 10.1.0. I wanted to add external storage using openStack.
When I have tried I enter all the requested information and only get a red square. It seems there is an issue with something.
Has anyone ever used OVH’s openstack for External Storage?
I was able to figure out the setting for
- region
- Bucket
- Request timeout
- username
- Password
- Tenant
However I was not sure about the following items:
*Service Name
- Identity Endpoint URL.
For the Identity Endpoint URL I tried this for OVH have much digging https://auth.cloud.ovh.net/v2.0/. I’ve used this URL with a system called centreStack to setup storage and the credentials I used on that system worked, so I tried to use them here. They don’t work here on Owncloud. Maybe the difference is openStack v1.0 vs v2.0 or is Swift neither of v1 or v2 ?
I personally think it is the Endpoint URL, but cannot get support from OVH on this and cannot seem to figure it out for myself either.
