I am using OwnCloud which is installed via Softacolous, a service of my hosting provider. I created myself as the administrator. Clicking on Personal - Storage limit OC tells me the operator has switch off external storage. Clicking on Manager* - Storage limit OC has a checked box Switch on External Storage. Beneath I see a line "smbclient is not installed..."
I try to connect Dropbox to OwnCloud, but it can't check my authentication key and password.
What is going wrong?
Regards, Guido
I do not know the right English terms, I am using the Dutch interface.
I am using OwnCloud 10.0.3. Because it is on a shared server, I can't access the installation files of these OwnCloud, so I am not able to install the Windows Network Drive App. I created an API, but I do not know if the settings in the API are correct.
After that I entered the auth key and secret key into OwnCloud. OwnCloud said: Fetching requested tokens failed. Verify your app key and secret key are correct
