Dears All
I am facing problem after installed owncloud on ubuntu server 16.04. i think that main page is not compile as well.
shown blew
<?php
* @author Jörn Friedrich Dreyer <jfd@butonic.de>
* @author Lukas Reschke <lukas@statuscode.ch>
* @author Morris Jobke <hey@morrisjobke.de>
* @author Philipp Schaffrath <github@philippschaffrath.de>
* @author RealRancor <fisch.666@gmx.de>
* @author Robin Appelman <icewind@owncloud.com>
* @author Sergio BertolÃn <sbertolin@solidgear.es>
* @author Thomas Müller <thomas.mueller@tmit.eu>
* @author Vincent Petry <pvince81@owncloud.com>
* @copyright Copyright (c) 2017, ownCloud GmbH
* @license AGPL-3.0
* This code is free software: you can redistribute it and/or modify
* it under the terms of the GNU Affero General Public License, version 3,
* as published by the Free Software Foundation.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU Affero General Public License for more details.
* You should have received a copy of the GNU Affero General Public License, version 3,
* along with this program. If not, see <http://www.gnu.org/licenses/>
// Show warning if a PHP version below 5.6.0 is used, this has to happen here
// because base.php will already use 5.6 syntax.
if (version_compare(PHP_VERSION, '5.6.0') === -1) {
echo 'This version of ownCloud requires at least PHP 5.6.0<br/>';
echo 'You are currently running ' . PHP_VERSION . '. Please update your PHP version.';
return;
// Show warning if PHP 7.2 is used as ownCloud is not compatible with PHP 7.2
if (version_compare(PHP_VERSION, '7.2.0alpha1') !== -1) {
echo 'This version of ownCloud is not compatible with PHP 7.2<br/>';
echo 'You are currently running ' . PHP_VERSION . '.';
return;
everything on server working well (php,mysql,apache)
would you mind to help me please ?
yes , but i find out one mistake , the problem was inside /etc/apache2/sites-enabled/owncloud.conf
i missed to configure Satisfy Any
so now working fine
thank you again for your replay.
Возникла проблема после установки owncloud на сервере Ubuntu 19.10
<?php
* @author JГ¶rn Friedrich Dreyer <jfd@butonic.de>
* @author Sergio BertolГn <sbertolin@solidgear.es>
* @author Thomas MГјller <thomas.mueller@tmit.eu>
* @copyright Copyright (c) 2018, ownCloud GmbH
* @license AGPL-3.0
// Show warning if a PHP version below 7.0.7 is used, this has to happen here
// because base.php will already use 7.0 syntax.
if (\version_compare(PHP_VERSION, '7.0.7') === -1) {
echo 'This version of ownCloud requires at least PHP 7.0.7<br/>';
echo 'You are currently running PHP ' . PHP_VERSION . '. Please update your PHP version.';
return;
// Show warning if PHP 7.4 or later is used as ownCloud is not compatible with PHP 7.4
if (\version_compare(PHP_VERSION, '7.4.0alpha1') !== -1) {
echo 'This version of ownCloud is not compatible with PHP 7.4<br/>';
echo 'You are currently running PHP ' . PHP_VERSION . '.';
return;
// running oC on Windows is unsupported since 8.1, this has to happen here because
// is seems that the autoloader on Windows fails later and just throws an exception.
if (\stripos(PHP_OS, 'WIN') === 0) {
echo 'ownCloud Server does not support Microsoft Windows.';
return;
try {
require_once __DIR__ . '/lib/base.php';
OC::handleRequest();
} catch (\OC\ServiceUnavailableException $ex) {
\OC::$server->getLogger()->logException($ex, ['app' => 'index']);
//show the user a detailed error page
OC_Response::setStatus(OC_Response::STATUS_SERVICE_UNAVAILABLE);
OC_Template::printExceptionErrorPage($ex);
} catch (\OC\HintException $ex) {
OC_Template::printErrorPage($ex->getMessage(), $ex->getHint());
} catch (\OC\User\LoginException $ex) {
OC_Response::setStatus(OC_Response::STATUS_FORBIDDEN);
OC_Template::printErrorPage($ex->getMessage());
} catch (\OCP\Files\ForbiddenException $ex) {
} catch (Exception $ex) {
try {
OC_Response::setStatus(OC_Response::STATUS_INTERNAL_SERVER_ERROR);
} catch (\Exception $ex2) {
// with some env issues, it can happen that the logger couldn't log properly,
// so print out the exception directly
echo('<html><body>');
echo('Exception occurred while logging exception: ' . $ex->getMessage() . '<br/>');
echo(\str_replace("\n", '<br/>', $ex->getTraceAsString()));
echo('</body></html>');
} catch (Error $ex) {
все на сервере работает хорошо (php, mysql, apache) не
могли бы вы мне помочь, пожалуйста?
