Failed to upgrade to OC 10.0.1
  1. sudo -u www php occ upgrade
Upgrading from 10.0.0 to 10.0.1
MySql triggers the following exception:
Doctrine\DBAL\Exception\DriverException: An exception occurred while executing ‘CREATE TABLE oc_account_terms (id BIGINT UNSIGNED AUTO_INCREMENT NOT NULL, account_id BIGINT UNSIGNED NOT NULL, term VARCHAR(256) NOT NULL, INDEX account_id_index (account_id), INDEX term_index (term), PRIMARY KEY(id)) DEFAULT CHARACTER SET utf8 COLLATE utf8_bin ENGINE = InnoDB’:
SQLSTATE[42000]: Syntax error or access violation: 1071 Specified key was too long; max key length is 767 bytes
Update failed
Operating system: FreeBSD 10.0.3
Nginx
mysql Ver 14.14 Distrib 5.6.36, for FreeBSD10.3 (amd64) using EditLine wrapper
PHP 5.6.30 (cli) (built: Mar 26 2017 07:21:27)
Copyright (c) 1997-2016 The PHP Group
Zend Engine v2.6.0, Copyright (c) 1998-2016 Zend Technologies
10.0.0
Freebsd 's ports tree
timeout
No access
Enabled:
  • activity: 2.3.4
  • calendar: 1.4.2
  • comments: 0.3.0
  • configreport: 0.1.1
  • contacts: 1.5.2
  • dav: 0.2.8
  • federatedfilesharing: 0.3.0
  • federation: 0.1.0
  • files: 1.5.1
  • files_external: 0.7.0
  • files_pdfviewer: 0.8.2
  • files_sharing: 0.10.0
  • files_texteditor: 2.2
  • files_trashbin: 0.9.0
  • files_versions: 1.3.0
  • files_videoplayer: 0.9.8
  • firstrunwizard: 1.1
  • market: 0.1.0
  • notifications: 0.3.0
  • provisioning_api: 0.5.0
  • systemtags: 0.3.0
  • templateeditor: 0.1
  • updatenotification: 0.2.1
    Disabled:
  • encryption
  • external
  • files_Enabled:
  • activity: 2.3.4
  • calendar: 1.4.2
  • comments: 0.3.0
  • contacts: 1.5.2
  • dav: 0.2.8
  • federation: 0.1.0
  • files: 1.5.1
  • market: 0.1.0
  • systemtags: 0.3.0
    Disabled:
  • encryption
  • external
  • files_antivirus
  • theme-example
  • user_external
    antivirus
  • theme-example
  • user_external
No
No
No
not defined
I also tried to create a table named ‘oc_account_term’ into the database ‘owncloud’, with the same entries by myself, using the mysql command line. Same error occured, with or without the innodb engine clause.
I’m not good enough with Mysql/InnoDB internals, but using VARCHAR(255) instead of VARCHAR(256) is somehow accepted on the command line …
So, do I only need to setup Mysql in a suitable way to make it granted VARCHAR(256) ?
As this is a FreeBSD port, you should probably raise it with the package maintainers first.
I did post a request on the freebsd ports mailing list at first place.
But, by the fact, the issue may regard to a table definition for the database engine. If true, the issue might be related to a mysql installation and/or configutation, not only to a FreeBSD usecase.
So, I wonder if there is not some clauses that are missing to be fully granted by Mysql in any way.
OK, they are working on a fix.
