I'm using Ubuntu 14.04 and OC 8.22. I just followed the instructions to upgrade OC 8.22 to 9.04 and it seems to have downloaded and installed 9.10 for some reason. Now I'm getting a failed upgrade using command "sudo -u www-data php occ upgrade" and getting this error: "Exception: Updates between multiple major versions and downgrades are unsupported. Update failed." Can somone help please? Why did it download 9.10 if it's not a compatible upgrade?
I followed these instructions: https://doc.owncloud.org/server/9.0/admin_manual/maintenance/package_upgrade.html
Thanks.
