- Setting up a fresh LAMP
- Following these commands: download.owncloud.org/download/repositories/10.0/owncloud/
apt-get update
Ign https://attic.owncloud.com/org/download/repositories/10.0/Ubuntu_18.04 InRealease
The packages should install flawless
The package gets ignored
Ubuntu Bionic 18.04.02
10.1.1
Fresh install
http://download.owncloud.org/download/repositories/10.0/owncloud/
maybe it helps to have a look at the manual of apt-get to see why this specific part gets ignored and how to configure apt to choose the expected packages?
But maybe you have just chosen the wrong repository? If i’m clicking on:
at the “Go to packages” link i’m getting redirected to:
https://download.owncloud.org/download/repositories/stable/owncloud/index.html
which seems to differ from your used link.
It seems you have also posted this in https://github.com/owncloud/core/issues/35071. I think you should avoid such postings on various places, especially as this doesn’t look like a bug in ownCloud (which AFAIK the “core” issue tracker is about) but about the usage of apt-get.
Thanks for the quick reply. This link shows more packages yet the particular one still gets ignored. Ign means apt tried to download something (such as translation or InRelease file) but didn't find, but that can be ignored, so proceed to the next thing.
This i found on StackExchange. So this one package seems to be a 404. Any ideas?
Typing https://attic.owncloud.com/org/download/repositories/production/Ubuntu_18.04
gets me
Error 404: Not found
I have no idea where that file is, sorry. Are you sure you typed in the correct URL?
So this one seems moved/dislocated, because neither /stable
nor /10.1
nor /production
finds this one. Any ideas?
