I am trying to share a directory with a user on another ownCloud server. However, this user has a space in his username (Firstname Lastname). So, instead of sharing the directory with username@urltoowncloudserver.com (which works, we’ve tried with another user without spaces), it seems I should share it with Firstname Lastname@urltoowncloudserver.com. My problem is that this URL is not accepted by my ownCloud server. What is the correct way (if any) to share with this user?
Both servers are running raspbian on raspberry pi 3. Apache and php are installed from the default repositories. The ownCloud version is in both cases 9.0.0.
Without the space in the username, the input field gives me a dropdown that I can select to share the folder. With the space, I get the error message (in Dutch) “no users or groups found”.
I have updated my server to 9.0.4 and still no luck in sharing my folder. I’m now waiting for my friend to update his server, since I don’t have access to it.
I will come back to you once this is finished. Thanks already for the help so far!
