- S3 as storage
- Folders are present in S3 bucket but not visible from OwnCloud
Folders are present in S3 bucket hence should be visible from OwnCloud
Operating system: Amazon Llinux
Web server:: Apache
Database:: MySQL
PHP version: 7.0.33
ownCloud version: 10.3.2
Where did you install ownCloud from: Owncloud downloads
Are you using encryption: yes/no : No
