Which is the recommended solution and has a second unit mounted on another volume and can no longer be associated with the file directory of the owncloud unit.
Although a hard link is capable of doing, is the same as a symbol but more dangerous for its management.
I mean it is discouraged to use hardlinks and use symlinks, except for a few occasions.
which is the recommended solution if you have a second drive mounted on another volume and you can no longer associate it with the file directory of the owncloud unit.
Could you help me?
Thank you
