File integrity check passes successfully after initial install
See integrity check results here (link below)
Operating system: Ubuntu Mate 20.04
Web server: Apache2
ownCloud version: [ownCloud ]10.6.0 (stable)
Where did you install ownCloud from: Followed instructions to add PPA to apt and installed from there.
Signing status (ownCloud 9.0 and above): ??
/index.php/settings/integrity/failed
