first off, thanks a lot to the OwnCloud developer team. It’s needless to say that this software is purely amazing.
Now let’s get to my little issue.
- Install OC 10.0.3
- Open it using your phone or the Google Chrome “phone simulation” with for example the Galaxy S5
It should list the files normally like it does on my installation of OC9.
Like this.
Depending on the size of the phone, only the first few letters or simply just three periods are being shown.
Like this.
What I do realize from inspecting it further is that in the old version for example the span with the class “uploadtext” is at the same spot as “innernametext”, whereas in the new version it is taking up a bit of space on the right of “innertext”. When I remove “uploadtext”, the problem doesn’t fully disappear, but there’s more text visible.
I suppose this is a glitch in the new design or I am simply doing something completely wrong.
imgur.com/a/JiQ3L Here is another screen shot of what it looks like.
Operating system: Debian Stretch (Debian Wheezy on alternative server where it shows the same behavior)
Web server: apache2
Database: MariaDB 10.1.26 (MySQL on alternative server…)
PHP version: 7.0 (5.0 on alternative server…)
ownCloud version: 10.0.3.3
Updated from an older ownCloud or fresh install: Updated from 9.0.3 (fresh install on alt server)
Where did you install ownCloud from: The zip file provided
Signing status (ownCloud 9.0 and above): gist:ade5220318f98339174a7a88be45f6b7 · GitHub
The content of config/config.php: gist:febd071952a06535116b8cfeb4d24ef9 · GitHub
List of activated apps: gist:b3e12ae16a44bab1ae675632f45f10a9 · GitHub
Are you using external storage, if yes which one: No, it’s all within the web directory.
Are you using encryption: No.
Are you using an external user-backend, if yes which one: No.
Browser: It’s critical on mobile browsers (iPhone and Android (Chrome)) as well as with the mobile simulation feature of Google Chrome desktop.
Operating system: Windows 7, Android, iOS…
There is nothing coming up in the error log when this happens.
It only keeps telling me that 'tipsy' is deprecated.
Sorry about the ugly links, the forum only allowed me to create two hyperlinks at max.
Thanks in advance for any possible help.
