I want to use owncloud to store my password database for syncing. This a *.kdbx file from KeePass Password Safe. Owncloud is hosted by my ISP.
Expected behavior
Tell us what should happen: File should sync
Actual behavior
Did not sync. Error Message (what I can see): "4…eePass/John.kdbx
- Try to sync a *.kdbx file (this is a database file from KeePass Password Safe)
Web server: Apache/Tomcat
ownCloud version: 10.3.2
Client version: 2.6.1 (Build 12992)
Operating system: Windows Home 64 bit
OS language:Windows
Installation path of client:
Gist: thetechnodino/20200312_1218_owncloud.log.0 (hopefully since I was not sure how to submit the post)
Client logfile: Output of
owncloud --logwindow
orowncloud --logfile log.txt
(On Windows usingcmd.exe
, you might need to firstcd
into the ownCloud directory)
(See also http://doc.owncloud.org/desktop/2.2/troubleshooting.html#client-logfile ) -
Web server error log:
