Files and settings not available after update to 10.4
I am relatively new to owncloud and have a problem after I updated to 10.4.
I cant get to my files anymore and only get the reply that the folder is not available.
Also the page for settings produces only a blank page
In my error log I found this
[26-Apr-2020 09:12:43 UTC] PHP Fatal error: Class OCA\FederatedFileSharing\FederatedShareProvider contains 1 abstract method and must therefore be declared abstract or implement the remaining methods (OCP\Share\IShareProvider::getProviderCapabilities) in /home/…/public_html/cloud/apps/federatedfilesharing/lib/FederatedShareProvider.php on line 49
Can anyone help?
Thanks!
Boris
i did the following search https://github.com/owncloud/core/search?q=“Class+OCA\\FederatedFileSharing\\FederatedShareProvider+contains”&type=Issues and found this issue below. If i’m understanding the second comment there this seems to be originating from an insufficiently / not correctly done update.
