Files external storage dont work
  1. Administration
  2. External storage
  3. Try to sharing a local directory but dont work. (permision is good)
I need to sharing local storage but i cant becouse plugin “files external storage” dont work
When i try to use external storage in local, for example sharing /tmp i cant and indicate a red “quadrate”. I check permisios (chmod and chown) and it is good.
Web server: Apache 2.4
Database: Mysql
PHP version: 5.6
ownCloud version (see ownCloud admin page): 8.2.2
external storage → dont work
Cannot modify header information - headers already sent
Integrity status for oC9+
paste the results here.
from the issue template you had filled out:
Before posting please snip make sure that you’re running the latest available version for your oC release: Changelog - ownCloud
oC 8.2.2 is far from beeing a current version (for 8.2.x version 8.2.10 is current). Please always use a current version like 8.2.10 to avoid that you’re hitting some possible bugs which might be fixed in newer versions.
