Hello everyone,
I use Owncloud 10.0.8 and I’m the only user on the system. but as soon as I set ‘filelocking.enabled’ => true,in the config.php I get almost always the error message that a file is locked although I haven’t touched it for hours.
I already configured Redis and APCu for the system and I use a system cron that runs every 15 min. but all those steps heven’t helped.
Does anyone have the same problem and may help me.?
I ask because at the moment ‘filelocking.enabled’ => false is set to make the system useable, But then I get a warning in Settings->General for the Admin that Transactional file locking is disabled.
Many thanks in advance for your help.
Setup a system like mine and log in as the only user on the system.
Set Apache as owner of all files of the installation and set the recommended file rights.
Try to upload more than one file or try to touch a file. You get a locked message.
No files locked due to the fact that only one user with one session is using the system..
Files I haven’t touched for hours are locked and I’m not able to upload or download things. The system is almost unuseable.
Ubuntu 16.04
Apache 2.4.18 (Ubuntu)
MariaDB 10.2.12
7.0.28 (Ubuntu)
Redis version
Redis: 3.2.10
10.0.8
Updated from 10.0.7 but the behaviour was the same on 10.0.7
Installed Owncloud repository for Ubuntu 16.04.and then run apt-get install owncloud-files
“basic”: {
“license key”: “REMOVED SENSITIVE VALUE”,
“date”: “Mon, 23 Apr 2018 01:58:54 +0000”,
“ownCloud version”: “10.0.8.5”,
“ownCloud version string”: “10.0.8”,
“ownCloud edition”: “Enterprise”,
“server OS”: “Linux”,
“server OS version”: “Linux ip-172-31-172-43 4.4.0-1054-aws #63-Ubuntu SMP Wed Mar 28 19:42:42 UTC 2018 x86_64”,
“server SAPI”: “apache2handler”,
“webserver version”: “Apache/2.4.18 (Ubuntu)”,
“hostname”: “loony.info”,
“user count”: 2,
“user directories”: 2,
“logged-in user”: “REMOVED SENSITIVE VALUE”
“config”: {
“updatechecker”: false,
“updater.server.url”: “https://updates.owncloud.com/server/”,
“has_internet_connection”: true,
“check_for_working_webdav”: true,
“check_for_working_wellknown_setup”: true,
“check_for_working_htaccess”: true,
“operation.mode”: “single-instance”,
“instanceid”: “ocgxrv4lh7zr”,
“trusted_domains”: [
“localhost”,
“loony.info”
“datadirectory”: “/mnt/efs/www/owncloud/data”,
“overwrite.cli.url”: “https://loony.info”,
“htaccess.RewriteBase”: “/”,
“dbtype”: “mysql”,
“version”: “10.0.8.5”,
“dbname”: “ownclouddb”,
“dbhost”: “loonyinfo.cgjmc5efrkph.eu-west-1.rds.amazonaws.com”,
“dbtableprefix”: “oc_”,
“mysql.utf8mb4”: true,
“logtimezone”: “UTC”,
“installed”: true,
“memcache.local”: “\OC\Memcache\APCu”,
“filelocking.enabled”: false,
“filelocking.ttl”: 60,
“memcache.locking”: “\OC\Memcache\Redis”,
“memcache.distributed”: “\OC\Memcache\Redis”,
“redis”: {
“host”: “loonyredis.wq1zqa.clustercfg.euw1.cache.amazonaws.com”,
“port”: 6379,
“timeout”: 0,
“password”: “REMOVED SENSITIVE VALUE”
“mail_smtpmode”: “smtp”,
“mail_smtpauthtype”: “LOGIN”,
“mail_smtpauth”: 1,
“mail_smtpsecure”: “ssl”,
“mail_smtpport”: “465”,
“mail_smtpname”: “REMOVED SENSITIVE VALUE”,
“mail_smtppassword”: “REMOVED SENSITIVE VALUE”,
“loglevel”: 3,
“singleuser”: false,
“maintenance”: false,
“upgrade.automatic-app-update”: true
“integritychecker”: {
“passing”: true,
“enabled”: true,
“result”:
“core”: {
“allow_user_mount_sharing”: “yes”,
“backgroundjobs_mode”: “cron”,
“default_encryption_module”: “OC_DEFAULT_MODULE”,
“enable_external_storage”: “yes”,
“encryption_enabled”: “yes”,
“installedat”: “1520676864.3005”,
“lastcron”: “1524447907”,
“lastupdateResult”: “”,
“lastupdatedat”: “1524448690”,
“public_files”: “files_sharing/public.php”,
“public_webdav”: “dav/appinfo/v1/publicwebdav.php”,
“remote_nonshib-webdav”: “user_shibboleth/appinfo/remote.php”,
“shareapi_allow_public_notification”: “yes”,
“umgmt_send_email”: “true”,
“umgmt_show_backend”: “true”,
“umgmt_show_email”: “true”,
“umgmt_show_is_enabled”: “true”,
“umgmt_show_last_login”: “true”,
“umgmt_show_storage_location”: “true”,
“vendor”: “owncloud”
The rest I deleted due to size limitations.
