Files missing after a few hours
Hi all,
My files are missing in the Web UI. The files appear again after running repair, but disappear after some time. These files are located in an encrypted partition (I.e. I moved them out of the owncloud folder).
I’m after some guidance on debugging this. I’ve checked the oc_accounts table and everything was ok there. I’ve also read some similar questions but can’t quite work out what is wrong.
  1. Leave owncloud for a day or so
  2. Navigate to /owncloud/index.php/settings/personal
  3. Files are missing
This can be fixed by running
sudo -u www-data php occ maintenance:singleuser --on
sudo -u www-data php occ files:scan --all --repair
sudo -u www-data php occ maintenance:singleuser --off
However, after some time the files are missing again. I’m going to pop that into a corn job but it doesn’t seem ideal?
Files should be listed
Files are missing
Debian 10
Apache 2
Postgres
10.6.0
Newish install (October). Updated recently to 10.6. Not sure if issues predated this.
apt
{        "system": {        "updatechecker": false,        "passwordsalt": "***REMOVED SENSITIVE VALUE***",        "secret": "***REMOVED SENSITIVE VALUE***",        "trusted_domains": [        "localhost",        "cloud.goodwin-jones.com"        ],        "datadirectory": "\/mnt\/vault\/owncloud",        "overwrite.cli.url": "http:\/\/localhost",        "dbtype": "pgsql",        "version": "10.6.0.5",        "dbname": "owncloud",        "dbhost": "localhost",        "dbtableprefix": "oc_",        "dbuser": "***REMOVED SENSITIVE VALUE***",        "dbpassword": "***REMOVED SENSITIVE VALUE***",        "logtimezone": "UTC",        "apps_paths": [        {        "path": "\/var\/www\/owncloud\/apps",        "url": "\/apps",        "writable": false        },        {        "path": "\/var\/www\/owncloud\/apps-external",        "url": "\/apps-external",        "writable": true        }        ],        "installed": true,        "instanceid": "ocujg2yvld86",        "theme": "",        "memcache.local": "\\OC\\Memcache\\APCu",        "memcache.locking": "\\OC\\Memcache\\Redis",        "redis": {        "host": "localhost",        "port": 6379        },        "loglevel": 2,        "maintenance": false,        "singleuser": false        }        }
Enabled:
  - activity: 2.6.0
  - comments: 0.3.0
  - configreport: 0.2.0
  - dav: 0.6.0
  - federatedfilesharing: 0.5.0
  - federation: 0.1.0
  - files: 1.5.2
  - files_external: 0.7.1
  - files_external_dropbox: 1.2.0
  - files_mediaviewer: 1.0.4
  - files_pdfviewer: 0.11.2
  - files_sharing: 0.14.0
  - files_texteditor: 2.3.0
  - files_trashbin: 0.9.1
  - files_versions: 1.3.0
  - firstrunwizard: 1.2.0
  - market: 0.6.0
  - notifications: 0.5.2
  - provisioning_api: 0.5.0
  - systemtags: 0.3.0
  - templateeditor: 0.4.0
  - updatenotification: 0.2.1
Disabled:
  - admin_audit
  - announcementcenter
  - customgroups
  - encryption
  - enterprise_key
  - external
  - files_antivirus
  - files_classifier
  - files_external_ftp
  - files_ldap_home
  - files_lifecycle
  - firewall
  - graphapi
  - guests
  - oauth2
  - openidconnect
  - password_policy
  - ransomware_protection
  - sharepoint
  - systemtags_management
  - theme-enterprise
  - user_external
  - user_ldap
  - user_shibboleth
  - windows_network_drive
  - wopi
  - workflow
Are you using encryption: no
Browser: Firefox
Operating system: Windows
After further debugging, it seems the “hard refresh” in the browser is the key to getting the files to appear, rather than the rescan.
I suspect two interlinked issues here:
  1. A client-side bug in Firefox where files do not appear without a hard refresh (perhaps some weird caching error?).
  2. A server-side issue where for some reason the file list goes out of date?
I’ve disabled the cron job and I update this post with some answers as and when I find them.
After further debugging.
  1. The client-side bug only exists in firefox but not in chrome.
  2. The file list only needs to be refreshed after a reboot.
I suspect issue 2 occurs when owncloud tries to access the file system before I decrypt the partition, so this is a non-issue and that part is closed, IMHO.
Issue 1 looks like a firefox bug. Possibly related to the following
a) My Files Not Showing In Firefox Browser
I have opened https://github.com/owncloud/core/issues/38451 to track this issue and for completeness.
