Hi, I am having problem with first user login. I mean user are authenticated against active directory 2008 and in previuos version I had to just insert user in the right AD group; nowadays (after migrating to 10 and conversion of db to uft8mb4) new user are unable to login. The error, looking in owncloud.log, seems to be in objectGUID field recognized as malformed utf8.
As workaround I have to insert manually the user in table oc_ldap_user_mapping.
Any clue?
thank you
Daniele
- first login
- owc reply user/password incorrect
user should login
login denied
Ubuntu 16.04.5 LTS- Linux vmcloud 4.4.0-137-generic #163-Ubuntu SMP Mon Sep 24 13:14:43 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
apache2 2.4.18-2ubuntu3.9
mysql-server 5.7.23-0ubuntu0.16
php7.0 7.0.32-0ubuntu0.16
10.0.9.5
updated from ver 9
tarball
âsystemâ: {
âinstanceidâ: âoctr84l01bm4â,
âpasswordsaltâ: âREMOVED SENSITIVE VALUEâ,
âsecretâ: âREMOVED SENSITIVE VALUEâ,
âtrusted_domainsâ: [
â192.168.222.39â,
âdatadirectoryâ: â/var/www/owncloud/dataâ,
âoverwrite.cli.urlâ: âREMOVED SENSITIVE VALUEâ,
âdbtypeâ: âmysqlâ,
âversionâ: â10.0.9.5â,
âdbnameâ: âowncloudâ,
âdbhostâ: âlocalhostâ,
âdbtableprefixâ: âoc_â,
âmysql.utf8mb4â: true,
âdbuserâ: âREMOVED SENSITIVE VALUEâ,
âdbpasswordâ: âREMOVED SENSITIVE VALUEâ,
âlogtimezoneâ: âEurope/Romeâ,
âloglevelâ: 0,
âinstalledâ: true,
âldapIgnoreNamingRulesâ: false,
âmaintenanceâ: false,
âsingleuserâ: false,
âmemcache.localâ: â\OC\Memcache\APCuâ,
âmail_smtpmodeâ: âphpâ,
âupdater.secretâ: âREMOVED SENSITIVE VALUEâ
Enabled:
- comments: 0.3.0
- configreport: 0.1.1
- dav: 0.3.2
- federatedfilesharing: 0.3.1
- federation: 0.1.0
- files: 1.5.1
- files_external: 0.7.1
- files_sharing: 0.10.1
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- files_videoplayer: 0.9.8
- firstrunwizard: 1.1
- market: 0.2.5
- notifications: 0.3.4
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- templateeditor: 0.3.1
- updatenotification: 0.2.1
- user_ldap: 0.11.0
Disabled: - encryption
- external
- user_external
Are you using external storage, if yes which one: local/smb/sftp/âŠ
no
no
Are you using an external user-backend, if yes which one: LDAP/ActiveDirectory/Webdav/âŠ
ActiveDirectory
| Configuration | |
| hasMemberOfFilterSupport | 1 |
| hasPagedResultSupport | |
| homeFolderNamingRule | |
| lastJpegPhotoLookup | 0 |
| ldapAgentName | CN=ldap_browser,OU=Domain Controllers,DC=xxx,DC=yyy |
| ldapAgentPassword | *** |
| ldapAttributesForGroupSearch | |
| ldapAttributesForUserSearch | sn;givenName |
| ldapBackupHost | 172.18.10.24 |
| ldapBackupPort | 389 |
| ldapBase | DC=xxx,DC=yyy |
| ldapBaseGroups | DC=xxx,DC=yyy |
| ldapBaseUsers | DC=xxx,DC=yyy |
| ldapCacheTTL | 600 |
| ldapConfigurationActive | 1 |
| ldapDynamicGroupMemberURL | |
| ldapEmailAttribute | mail |
| ldapExperiencedAdmin | 0 |
| ldapExpertUUIDGroupAttr | |
| ldapExpertUUIDUserAttr | objectguid |
| ldapExpertUsernameAttr | userPrincipalName@xxx.yyy |
| ldapGroupDisplayName | cn |
| ldapGroupFilter | (&(|(objectclass=group))(|(cn=grp_owncloud))) |
| ldapGroupFilterGroups | grp_owncloud |
| ldapGroupFilterMode | 0 |
| ldapGroupFilterObjectclass | group |
| ldapGroupMemberAssocAttr | member |
| ldapHost | 172.18.10.23 |
| ldapIgnoreNamingRules | |
| ldapLoginFilter | (&(&(|(objectclass=organizationalPerson))(|(|(memberof=CN=grp_owncloud,CN=Users,DC=xxx,DC=yyy)(primaryGroupID=13661))))(samaccountname=%uid)) |
| ldapLoginFilterAttributes | |
| ldapLoginFilterEmail | 0 |
| ldapLoginFilterMode | 0 |
| ldapLoginFilterUsername | 1 |
| ldapNestedGroups | 0 |
| ldapOverrideMainServer | |
| ldapPagingSize | 5000 |
| ldapPort | 389 |
| ldapQuotaAttribute | |
| ldapQuotaDefault | |
| ldapTLS | 0 |
| ldapUserDisplayName | displayname |
| ldapUserDisplayName2 | |
| ldapUserFilter | (&(|(objectclass=organizationalPerson))(|(|(memberof=CN=grp_owncloud,CN=Users,DC=xxx,DC=yyy)(primaryGroupID=13661)))) |
| ldapUserFilterGroups | grp_owncloud |
| ldapUserFilterMode | 0 |
| ldapUserFilterObjectclass | organizationalPerson |
| ldapUuidGroupAttribute | auto |
| ldapUuidUserAttribute | auto |
| turnOffCertCheck | 1 |
| useMemberOfToDetectMembership | 1 |
| Configuration | s01 |
| ldapHost | 172.18.10.24 |
| ldapPort | 389 |
| ldapQuotaDefault | default |
| ldapTLS | 0 |
firefox 62
linux Ubuntu 18.04.1 LTS
{âreqIdâ:âb4PjNOqUqtQGm5wjkex4â,âlevelâ:3,âtimeâ:â2018-10-11T08:43:10+02:00â,âremoteAddrâ:â172.18.110.26â,âuserâ:"â",âappâ:âuser_ldapâ,âmethodâ:âPOSTâ,âurlâ:"/index.php/login",âmessageâ:âException: {âExceptionâ:âOutOfBoundsExceptionâ,âMessageâ:âCannot determine username for cn=xxxxx yyyyyyy,ou=gruppi solo utenti,dc=ced,dc=aos from {\âdn\â:[\âcn=xxxxx yyyyyyy,ou=gruppi solo utenti,dc=ced,dc=aos\â],\âsamaccountname\â:[\âr.xxxxx\â],\âmail\â:[\âr.xxxxx@xxxxxx.xxx\â],\âdisplayname\â:[\âyyyyyyy xxxxx\â],\âsn\â:[\âxxxxx\â],\âgivenname\â:[\âyyyyyyy\â],\âobjectguid\â:[null]}, Malformed UTF-8 characters, possibly incorrectly encodedâ,âCodeâ:0,âTraceâ:â#0 \/var\/www\/owncloud\/apps\/user_ldap\/lib\/User\/Manager.php(311): OCA\\User_LDAP\\User\\UserEntry->getUsername()\n#1 \/var\/www\/owncloud\/apps\/user_ldap\/lib\/User\/Manager.php(224): OCA\\User_LDAP\\User\\Manager->resolveUID(Object(OCA\\User_LDAP\\User\\UserEntry))\n#2 \/var\/www\/owncloud\/apps\/user_ldap\/lib\/User\/Manager.php(426): OCA\\User_LDAP\\User\\Manager->getFromEntry(Array)\n#3 \/var\/www\/owncloud\/apps\/user_ldap\/lib\/User_LDAP.php(140): OCA\\User_LDAP\\User\\Manager->getLDAPUserByLoginName(âr.xxxxxâ)\n#4 [internal function]: OCA\\User_LDAP\\User_LDAP->checkPassword(*** sensitive parameters replaced )\n#5 \/var\/www\/owncloud\/apps\/user_ldap\/lib\/User_Proxy.php(75): call_user_func_array(Array, Array)\n#6 \/var\/www\/owncloud\/apps\/user_ldap\/lib\/Proxy.php(145): OCA\\User_LDAP\\User_Proxy->walkBackends(âr.xxxxxâ, âcheckPasswordâ, Array)\n#7 \/var\/www\/owncloud\/apps\/user_ldap\/lib\/User_Proxy.php(180): OCA\\User_LDAP\\Proxy->handleRequest(âr.xxxxxâ, âcheckPasswordâ, Array)\n#8 \/var\/www\/owncloud\/lib\/private\/User\/Manager.php(252): OCA\\User_LDAP\\User_Proxy->checkPassword( sensitive parameters replaced )\n#9 \/var\/www\/owncloud\/lib\/private\/User\/Session.php(519): OC\\User\\Manager->checkPassword( sensitive parameters replaced )\n#10 \/var\/www\/owncloud\/lib\/private\/User\/Session.php(334): OC\\User\\Session->loginWithPassword( sensitive parameters replaced )\n#11 \/var\/www\/owncloud\/core\/Controller\/LoginController.php(204): OC\\User\\Session->login( sensitive parameters replaced )\n#12 [internal function]: OC\\Core\\Controller\\LoginController->tryLogin( sensitive parameters replaced ***)\n#13 \/var\/www\/owncloud\/lib\/private\/AppFramework\/Http\/Dispatcher.php(159): call_user_func_array(Array, Array)\n#14 \/var\/www\/owncloud\/lib\/private\/AppFramework\/Http\/Dispatcher.php(89): OC\\AppFramework\\Http\\Dispatcher->executeController(Object(OC\\Core\\Controller\\LoginController), âtryLoginâ)\n#15 \/var\/www\/owncloud\/lib\/private\/AppFramework\/App.php(103): OC\\AppFramework\\Http\\Dispatcher->dispatch(Object(OC\\Core\\Controller\\LoginController), âtryLoginâ)\n#16 \/var\/www\/owncloud\/lib\/private\/AppFramework\/Routing\/RouteActionHandler.php(46): OC\\AppFramework\\App::main(âLoginControllerâ, âtryLoginâ, Object(OC\\AppFramework\\DependencyInjection\\DIContainer), Array)\n#17 [internal function]: OC\\AppFramework\\Routing\\RouteActionHandler->__invoke(Array)\n#18 \/var\/www\/owncloud\/lib\/private\/Route\/Router.php(342): call_user_func(Object(OC\\AppFramework\\Routing\\RouteActionHandler), Array)\n#19 \/var\/www\/owncloud\/lib\/base.php(919): OC\\Route\\Router->match(â\/loginâ)\n#20 \/var\/www\/owncloud\/index.php(55): OC::handleRequest()\n#21 {main}",âFileâ:"\/var\/www\/owncloud\/apps\/user_ldap\/lib\/User\/UserEntry.php",âLineâ:110}"}
#### Browser log
c) âŠ
