Hello!
Owncloud 10.0 updated to 10.6.0.
The update was successful with no errors.
Please help me to solve this problem – Invalid Code Integrity Messages
I attach a list of files
sorry! I made a mistake in the lines and wrote the OwnCloud version incorrectly. Now I have corrected the description. List of Invalid Code Integrity Messages in Code Signing.txt file (1.4 MB)
You definitely did not install the official ownCloud package, which can bee seen in the extra files. Only download the archive from there https://owncloud.com/download-server/
I’d suggest to replace all the owncloud directory with the files from the official package (except config, data or any custom apps directory). Then try again.
So the package is indeed correct, but you obvisouly missed a step. Don’t just copy the new files over the old installation, but delete all the files and directories except those I mentioned before and then copy the new files.
