Dear All,
good morning!
I am new to the forum and to ownCloud.
At my University, I have a FreeNas large storage, that I want to make accessible to my whole Group.
This “server” has a fixed IP address, accessible from outside, that the University provided me.
I have setup a own cloud jail in FreeNas, following the instructions in the video
Of course, it doesn’t work.
Please, I have the following questions:
- the jail that I set up should have the same address as my FreeNas server to be accessible from outside? By default, it proposes a different IP address (only the last number changes, the other 3 numbers are the same: is it correct?).
- I use the plain cgi configuration, instead of the fast cgi: is it right?
- I follow the instructions for the php inclusion in /usr/local/etc/lighttpd/conf.d, I open Safari and put the IP address I have used for the jail, but at the end I receive the message
“404 - Not found” and Safari specifies “the site is unsafe”
If I use https is the same, and if I put /owncloud or /“the_jail_name” after the IP address (both with http and https), I obtain the very same message…
What can I do?
Please, help me.
Thanks truly much in advance and my very best regards
Giacomo
