- Clean install selecting MySQL/MariaDB option
It should install?
Just gives error to check owncloud.log and below is what it gives. No idea what the error is actually.
Linux dedi488.flk1.host-h.net 4.9.0-0.bpo.8-amd64 #1 SMP Debian 4.9.110-3+deb9u5~deb8u1 (2018-10-03) x86_64
Apache
mysqlnd 5.0.12-dev - 20150407
7.2.16-1+0~20190307202206.17+jessie~1.gbpa7be82
10.1.1
No.
Zip and Tar download and FTP upload.
$CONFIG = array (
‘instanceid’ => ‘och8br57xv4i’,
‘passwordsalt’ => ‘69cVvL+fSYbtRW9lvfBxdPBn8iavVK’,
‘secret’ => ‘DfG4Ud4LP7Fp/z+Mk5Q2JAyRkbKV8EolL5jSDq/BjHyfYvTL’,
‘trusted_domains’ =>
array (
0 => ‘DOMAIN’,
‘datadirectory’ => ‘/usr/www/users/cloudxznfb/data’,
‘overwrite.cli.url’ => ‘CLOUD LINK’,
‘dbtype’ => ‘mysql’,
‘version’ => ‘10.1.1.1’,
‘dbname’ => ‘racepicscloud’,
‘dbhost’ => ‘SERVER ADDRESS’,
‘dbtableprefix’ => ‘oc_’,
‘mysql.utf8mb4’ => true,
None
No.
No.
No.
Firefox
Windows 7
Nothing in server log.
{"reqId":"XKr-9l6CF6MAADXAPFkAAAAw","level":3,"time":"2019-04-08T08:01:58+00:00","remoteAddr":"196.40.111.5","user":"--","app":"index","method":"POST","url":"\/index.php","message":"Exception: {\"Exception\":\"Error\",\"Message\":\"Class 'Doctrine\\\\DBAL\\\\Exception\\\\ConnectionException' not found\",\"Code\":0,\"Trace\":\"#0 \\\/usr\\\/www\\\/users\\\/cloudxznfb\\\/lib\\\/composer\\\/doctrine\\\/dbal\\\/lib\\\/Doctrine\\\/DBAL\\\/DBALException.php(145): Doctrine\\\\DBAL\\\\Driver\\\\AbstractMySQLDriver->convertException('An exception oc...', Object(Doctrine\\\\DBAL\\\\Driver\\\\PDOException))\\n#1 \\\/usr\\\/www\\\/users\\\/cloudxznfb\\\/lib\\\/composer\\\/doctrine\\\/dbal\\\/lib\\\/Doctrine\\\/DBAL\\\/Driver\\\/PDOMySql\\\/Driver.php(47): Doctrine\\\\DBAL\\\\DBALException::driverException(Object(Doctrine\\\\DBAL\\\\Driver\\\\PDOMySql\\\\Driver), Object(Doctrine\\\\DBAL\\\\Driver\\\\PDOException))\\n#2 \\\/usr\\\/www\\\/users\\\/cloudxznfb\\\/lib\\\/composer\\\/doctrine\\\/dbal\\\/lib\\\/Doctrine\\\/DBAL\\\/Connection.php(360): Doctrine\\\\DBAL\\\\Driver\\\\PDOMySql\\\\Driver->connect(Array, 'racepicscloud', '2kRl8kn27gj2t2k...', Array)\\n#3 \\\/usr\\\/www\\\/users\\\/cloudxznfb\\\/lib\\\/private\\\/DB\\\/Connection.php(59): Doctrine\\\\DBAL\\\\Connection->connect()\\n#4 \\\/usr\\\/www\\\/users\\\/cloudxznfb\\\/lib\\\/composer\\\/doctrine\\\/dbal\\\/lib\\\/Doctrine\\\/DBAL\\\/Connection.php(429): OC\\\\DB\\\\Connection->connect()\\n#5 \\\/usr\\\/www\\\/users\\\/cloudxznfb\\\/lib\\\/composer\\\/doctrine\\\/dbal\\\/lib\\\/Doctrine\\\/DBAL\\\/Connection.php(389): Doctrine\\\\DBAL\\\\Connection->getDatabasePlatformVersion()\\n#6 \\\/usr\\\/www\\\/users\\\/cloudxznfb\\\/lib\\\/composer\\\/doctrine\\\/dbal\\\/lib\\\/Doctrine\\\/DBAL\\\/Connection.php(328): Doctrine\\\\DBAL\\\\Connection->detectDatabasePlatform()\\n#7 \\\/usr\\\/www\\\/users\\\/cloudxznfb\\\/lib\\\/composer\\\/doctrine\\\/dbal\\\/lib\\\/Doctrine\\\/DBAL\\\/Connection.php(623): Doctrine\\\\DBAL\\\\Connection->getDatabasePlatform()\\n#8 \\\/usr\\\/www\\\/users\\\/cloudxznfb\\\/lib\\\/private\\\/DB\\\/Connection.php(144): Doctrine\\\\DBAL\\\\Connection->setTransactionIsolation(2)\\n#9 \\\/usr\\\/www\\\/users\\\/cloudxznfb\\\/lib\\\/composer\\\/doctrine\\\/dbal\\\/lib\\\/Doctrine\\\/DBAL\\\/DriverManager.php(172): OC\\\\DB\\\\Connection->__construct(Array, Object(Doctrine\\\\DBAL\\\\Driver\\\\PDOMySql\\\\Driver), Object(Doctrine\\\\DBAL\\\\Configuration), Object(Doctrine\\\\Common\\\\EventManager))\\n#10 \\\/usr\\\/www\\\/users\\\/cloudxznfb\\\/lib\\\/private\\\/DB\\\/ConnectionFactory.php(145): Doctrine\\\\DBAL\\\\DriverManager::getConnection(Array, Object(Doctrine\\\\DBAL\\\\Configuration), Object(Doctrine\\\\Common\\\\EventManager))\\n#11 \\\/usr\\\/www\\\/users\\\/cloudxznfb\\\/lib\\\/private\\\/Setup\\\/MySQL.php(134): OC\\\\DB\\\\ConnectionFactory->getConnection('mysql', Array)\\n#12 \\\/usr\\\/www\\\/users\\\/cloudxznfb\\\/lib\\\/private\\\/Setup\\\/MySQL.php(39): OC\\\\Setup\\\\MySQL->connect()\\n#13 \\\/usr\\\/www\\\/users\\\/cloudxznfb\\\/lib\\\/private\\\/Setup.php(326): OC\\\\Setup\\\\MySQL->setupDatabase('Test')\\n#14 \\\/usr\\\/www\\\/users\\\/cloudxznfb\\\/core\\\/Controller\\\/SetupController.php(64): OC\\\\Setup->install(Array)\\n#15 \\\/usr\\\/www\\\/users\\\/cloudxznfb\\\/lib\\\/base.php(846): OC\\\\Core\\\\Controller\\\\SetupController->run(Array)\\n#16 \\\/usr\\\/www\\\/users\\\/cloudxznfb\\\/index.php(54): OC::handleRequest()\\n#17 {main}\",\"File\":\"\\\/usr\\\/www\\\/users\\\/cloudxznfb\\\/lib\\\/composer\\\/doctrine\\\/dbal\\\/lib\\\/Doctrine\\\/DBAL\\\/Driver\\\/AbstractMySQLDriver.php\",\"Line\":103}"}
I can simply not get ownCloud installed using MySQL/MariaDB option.
