FTP External storage issue - no logs
Operating system: Debian 8.9 64bits
Web server: Apache2
Database: MariaDB
PHP version: 7.0.23
ownCloud version: 10.0.0.3
Updated from an older ownCloud or fresh install: Fresh Install
Where did you install ownCloud from: https://owncloud.org/
My Issue
Hello there, I have a FTP on my ISP Box and I have this url to access it :
URL : ftpes://mylogin@mydomain.isp.com:38669
So, I used :
Login: mylogin
Password : mypassword
Host : mydomain.isp.com
Port : 38669
But this is not working. I tried to use “Secure with ftps://”, I tried to use “ftpes://mydomain.isp.com” in the Host entry, still nothing. Red square.
My iptables rules :
iptables -t filter -A OUTPUT -p tcp --dport 38669 -j ACCEPT
iptables --append INPUT --protocol tcp --dport 27601 --jump ACCEPT ## PASV Port
The weird thing, I tried it two days ago, and I got some logs :
“message”:“ftp_ssl_connect(): php_network_getaddresses: getaddrinfo failed: Name or service not known at /var/www/owncloud/lib/composer/league/flysystem/src/Adapter/Ftp.php#112”}
=> But I was able to ping mydomain.isp.com, and tried to add in the /etc/hosts file
mydomain.isp.com my-ip
But still nothing, so I removed it.
But then I tried it again yesterday and today, but I have 0 logs about ftp in owncloud. Absolutely NOTHING.
I ask for some advices !
Up ? I have made 0 advancements…
Did you check if it works without the iptables rules? If it works you’ll likely have a problem with the iptables rules.
Tried without the iptables rules, no changes.
Related to a bug : FTP only works with subdirectories · Issue #17 · owncloud/files_external_ftp · GitHub
Closing this thread.
