atakacs
November 30, 2018, 10:56am
1
Hello
Having an issue publishing an FTP mount point as external storage in OC 10.0.10 (newly deployed community server).
In the log I see message "Cannot connect to 172.16.50.202:22. Error 111. Connection refused
However our server (IIS) is (at the moment ?) not listening on port 22 (which is SSH ?) but only 21.
Should I “simply” make it listen there ?
dmitry
November 30, 2018, 11:15am
2
you could try
Are you sure the FTP server is configured directly?
atakacs
November 30, 2018, 11:30am
3
Not sure what you mean here. They both sit within the LAN (no NAT traversal issue).
You are quite right - let’s test it…
OC side I get
Exception: {\"Exception\":\"Exception\",\"Message\":\"Login failed\"
FTP server shows
2018-11-30 11:02:47 172.16.50.210 - 172.16.50.202 22 ControlChannelOpened - - 0 0 58363854-4ab6-4475-8e13-804540ff67a7 -
2018-11-30 11:02:47 172.16.50.210 - 172.16.50.202 22 SSH-2.0-phpseclib_2.0 (openssl,+gmp) 500 87 0 58363854-4ab6-4475-8e13-804540ff67a7 -
2018-11-30 11:02:57 172.16.50.210 - 172.16.50.202 22 ControlChannelClosed - - 0 0 58363854-4ab6-4475-8e13-804540ff67a7 -
Yes, credentials are correct. That being said I can connect using WinSCP + FTP but not via WnSCP + SFTP… I guess I will have to dig into this.
If anyone managed to connect an IIS hosted FTP folder in OC I am all ears
dmitry
November 30, 2018, 11:41am
4
sorry, I meant correctly not directly
could it be possible that you’re mixing FTP/FTPS with SFTP? From what i know those are different protocols. The first are using port 21 where the latter is using 22.
atakacs
November 30, 2018, 12:24pm
6
You are in fact quite correct.
OC supports SFTP - which is in essence SSH - not much to do with FTP. In any case IIS will not be of help here.
dmitry
November 30, 2018, 3:10pm
7
why not just use samba share?
Because I can’t seem to have it working: External storage / SMB share redux
