Getting error in sync help me
synchronized stage ;
“not allowed because you don’t have permission to add subfolders to that folder”
I get an error message.
Help me please :frowning:
Please check the desktop sync log for the error:
https://doc.owncloud.com/desktop/2.6/troubleshooting.html
With the X-REQUEST-ID , you can grep for the related line in the owncloud.log (server). There you should see what isn’t working.
thanks for your answer was not helpful
Why was it not helpful?
Did you not find the error?
You tagged your post with 9.0.x and 9.1.x if you’re really still using server versions that old I would recommend upgrading.
