Hello, we have an odd bug on our Server. Do you have any idea?
1.Add a new group to an user
2.User is deconnecting
3.the new group is not affected on the user
The group affected on the user’s interface stay on the account
The group disappear
Operating system: Redhat
Web server: Apache
Database: MariaDB
**PHP version:**7
ownCloud version: 10.0.2
Updated from an older ownCloud or fresh install: older owncloud
*Are you using external storage, if yes which one: NO
Are you using encryption: yes/no NO
**Are you using an external user-backend, if yes which one: NO
No error
No error
