What is the recommended way to handle git repos? Currently, .git folders are not synced with ownCloud. I’m guessing because the pattern is matched in the ignored files?
Which pattern must I remove for .git folders to be synced with owncloud? Is this even recommended? Syncing .git folders seems to cause problems of its own.
Thank you for your answer! I have changed the settings so that hidden files and folders are not ignored. However, this does not seem to suffice, as I cannot see my git folder when I regard the git repo via the browser interface. Are .git folders additionally ignored via patterns?
