- run these commands:
sudo apt install php-apcu redis-server php-redis
nano /etc/redis/redis.conf
change port 6379 to port 0
Uncoment:
unixsocket /var/run/redis/redis.sock
and
unixsocketperm 700
change to unixsocketperm 770
save and quit
- run:
sudo usermod -a -G redis www-data
sudo service apache2 restart
sudo service redis-server start
- add this right before the );
'memcache.local' => '\OC\Memcache\APCu',
'filelocking.enabled' => 'true',
'redis' =>
array (
'host' => '/var/run/redis/redis-server.sock',
'port' => 0,
'timeout' => 0.0,
sudo systemctl enable redis-server
Redis should work as expected
website works .. I can go into the gallery. But when I click on an image I get an error message
"**ownCloud**
**Internal Server Error**
**Technical details**
**Remote Address: REMOVED SENSITVE DATA**
**Request ID: wH03VGjwainhxpPo0kXF**
**ownCloud – A safe home for all your data**"
ubuntu 18.04
self hosted
mysql
latest version as yesterday
10.0.9
Fresh install
I used the digital Ocean owncloud on Ubuntu 18.04 guide
<?php
$CONFIG = array (
'updatechecker' => false,
'instanceid' => 'ocm6znwhpkui',
'passwordsalt' => "***REMOVED SENSITIVE VALUE***",
'secret' => "***REMOVED SENSITIVE VALUE***",
'trusted_domains' =>
array (
0 => 'example.com',
'datadirectory' => '/var/www/owncloud/data',
'overwrite.cli.url' => 'https://example.com',
'dbtype' => 'mysql',
'version' => '10.0.9.5',
'dbname' => 'owncloud',
'dbhost' => 'localhost',
'dbtableprefix' => 'oc_',
'mysql.utf8mb4' => true,
'dbuser' => "***REMOVED SENSITIVE VALUE***",
'dbpassword' => "***REMOVED SENSITIVE VALUE***",
'logtimezone' => 'UTC',
'installed' => true,
'redis' =>
array (
'port' => 0,
'timeout' => 0.0,
Maybe there is an issue with an ’ ); or ), ??
OUPUT IS:
<?php
$CONFIG = array (
array (
0 => 'example.com',
'redis' =>
array (
'port' => 0,
'timeout' => 0.0,
LIST OF APPS:
Enabled:
- comments: 0.3.0
- configreport: 0.1.1
- dav: 0.3.2
- federatedfilesharing: 0.3.1
- federation: 0.1.0
- files: 1.5.1
- files_external: 0.7.1
- files_pdfviewer: 0.9.0
- files_sharing: 0.10.1
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- files_videoplayer: 0.9.8
- firstrunwizard: 1.1
- gallery: 16.1.0
- market: 0.2.5
- notifications: 0.3.4
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- updatenotification: 0.2.1
Disabled:
- encryption
- external
- user_external
no
no
no
OUTPUT:
There are no commands defined in the "ldap" namespace.
Chrome
Ubuntu 18.04
#### Web server error log
none
none
{"reqId":"2Drukm4F8vrrCOuoVvIO","level":3,"time":"2018-07-31T23:37:53+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"mysql.setup","method":"POST","url":"\/index.php","message":"Specific user creation failed: An exception$
{"reqId":"2Drukm4F8vrrCOuoVvIO","level":3,"time":"2018-07-31T23:38:00+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"no app in context","method":"POST","url":"\/index.php","message":"User backend OC\\User\\Database is re$
{"reqId":"gncVFaMEvVm2u7o5hIk7","level":3,"time":"2018-07-31T23:38:14+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/index.php\/apps\/files\/","message":"ini_set(): A session is active. You c$
{"reqId":"aLzZq7UF6mzdkeMaSszy","level":3,"time":"2018-07-31T23:38:15+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/index.php\/login?redirect_url=%252Findex.php%252Fapps%252Ffiles%252F","mes$
{"reqId":"dZb5hwH4oQkJuNAJ0G5j","level":3,"time":"2018-07-31T23:38:15+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/index.php\/core\/js\/oc.js?v=a9e1a600d8a15933c86dcad2284676cf","message":"$
{"reqId":"fQ4p376VpeFC5DxU1RoZ","level":3,"time":"2018-07-31T23:38:16+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/cron.php","message":"ini_set(): A session is active. You cannot change the$
{"reqId":"rnET0aSF0WZU1nfT9nAg","level":3,"time":"2018-07-31T23:38:22+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"POST","url":"\/index.php\/login?redirect_url=%252Findex.php%252Fapps%252Ffiles%252F","me$
{"reqId":"5oxO0fLfvXn3c8hf2Q4Z","level":3,"time":"2018-07-31T23:38:23+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/index.php\/apps\/files\/","message":"ini_set(): A session is active. You c$
{"reqId":"3aNBG4GchID4wbk7ebhe","level":3,"time":"2018-07-31T23:38:24+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/index.php\/core\/js\/oc.js?v=a9e1a600d8a15933c86dcad2284676cf","message":"$
{"reqId":"MDfBLce2ejiuSgq93apO","level":3,"time":"2018-07-31T23:38:25+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/cron.php","message":"ini_set(): A session is active. You cannot change the$
{"reqId":"ynXqV8IgA3jcAQLE8Jv2","level":3,"time":"2018-07-31T23:38:25+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/index.php\/apps\/firstrunwizard\/wizard.php","message":"ini_set(): A sessi$
{"reqId":"UvanqV2dstVZ8LcmOVyH","level":3,"time":"2018-07-31T23:38:25+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/ocs\/v2.php\/apps\/notifications\/api\/v1\/notifications?format=json","mes$
{"reqId":"13z6E9t2TpiqZhlXjNfR","level":3,"time":"2018-07-31T23:38:25+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/index.php\/avatar\/REMOVED SENSITVE DATA\/31","message":"ini_set(): A session is active. Yo$
{"reqId":"F2w4neHVfYaM0909dkMd","level":3,"time":"2018-07-31T23:38:25+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"PROPFIND","url":"\/remote.php\/webdav\/","message":"ini_set(): A session is active. You $
{"reqId":"6rPrYIPAQcIn5sFjJUPQ","level":3,"time":"2018-07-31T23:38:25+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/index.php\/avatar\/REMOVED SENSITVE DATA\/31","message":"ini_set(): A session is active. Yo$
{"reqId":"v553HAhOOTEWyvhGyddm","level":3,"time":"2018-07-31T23:38:25+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/index.php\/apps\/files\/ajax\/getstoragestats.php?dir=%2F","message":"ini_$
{"reqId":"vo6ydioC8qBhohWMojqB","level":3,"time":"2018-07-31T23:38:28+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/index.php\/apps\/firstrunwizard\/ajax\/disable.php","message":"ini_set(): $
{"reqId":"hOdWVJi5hbHFglIvAe4I","level":3,"time":"2018-07-31T23:38:28+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/ocs\/v2.php\/apps\/files_sharing\/api\/v1\/shares?format=json&path=%2FDocu$
{"reqId":"aOdylhq83bF8gEgqoTBU","level":3,"time":"2018-07-31T23:38:28+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/ocs\/v2.php\/apps\/files_sharing\/api\/v1\/shares?format=json&path=%2FDocu$
{"reqId":"emLSLLqXLJ5Ra6RWMzRN","level":3,"time":"2018-07-31T23:38:28+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/index.php\/avatar\/REMOVED SENSITVE DATA\/31","message":"ini_set(): A session is active. Yo$
{"reqId":"PcGWdE0pCfad2DhJqJ4s","level":3,"time":"2018-07-31T23:38:28+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"REPORT","url":"\/remote.php\/dav\/comments\/files\/5\/","message":"ini_set(): A session $
{"reqId":"xaE4nGR6qzrzdAtnK10x","level":3,"time":"2018-07-31T23:38:28+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"PROPFIND","url":"\/remote.php\/dav\/systemtags-relations\/files\/5","message":"ini_set()$
{"reqId":"cLW60Nn8lsBEkEU0tGbF","level":3,"time":"2018-07-31T23:38:30+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"POST","url":"\/index.php\/apps\/files\/api\/v1\/sorting","message":"ini_set(): A session$
{"reqId":"814bUq86ed09YL1JiCBZ","level":3,"time":"2018-07-31T23:38:31+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/ocs\/v2.php\/apps\/files_sharing\/api\/v1\/shares?format=json&path=%2FPhot$
{"reqId":"Y8BbhWPFJCC12TF68cGv","level":3,"time":"2018-07-31T23:38:32+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"PROPFIND","url":"\/remote.php\/dav\/systemtags-relations\/files\/7","message":"ini_set()$
{"reqId":"1ABwxC3xu5cSeCQH6CGQ","level":3,"time":"2018-07-31T23:38:32+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/ocs\/v2.php\/apps\/files_sharing\/api\/v1\/shares?format=json&path=%2FPhot$
{"reqId":"9LDB49OAQA5G9IJ5OfjQ","level":3,"time":"2018-07-31T23:38:33+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"PROPFIND","url":"\/remote.php\/webdav\/Photos","message":"ini_set(): A session is active$
{"reqId":"hHB7QQ5gmiKmJWoGmTOQ","level":3,"time":"2018-07-31T23:38:33+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/index.php\/apps\/files\/ajax\/getstoragestats.php?dir=%2FPhotos","message"$
{"reqId":"ROvLsonKHnFRqD6sRVl3","level":3,"time":"2018-07-31T23:38:33+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/remote.php\/dav\/files\/REMOVED SENSITVE DATA\/Photos\/San%20Francisco.jpg?c=82c43d59768f60$
{"reqId":"fkUSKIW3nHa9gbiRDQBA","level":3,"time":"2018-07-31T23:38:34+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/remote.php\/dav\/files\/REMOVED SENSITVE DATA\/Photos\/Squirrel.jpg?c=df19cef774662f71c981f$
{"reqId":"4LqEZmnOmJiqYKz6bKU7","level":3,"time":"2018-07-31T23:38:34+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/remote.php\/dav\/files\/REMOVED SENSITVE DATA\/Photos\/Paris.jpg?c=f494c4e03beac3618ae2ecd6$
{"reqId":"iOJhrTjAVww33aSFDDjh","level":3,"time":"2018-07-31T23:38:37+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"DELETE","url":"\/remote.php\/webdav\/Photos\/Paris.jpg","message":"ini_set(): A session $
{"reqId":"njJdCexfeGIB3piZWWLC","level":3,"time":"2018-07-31T23:38:37+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"DELETE","url":"\/remote.php\/webdav\/Photos\/San%20Francisco.jpg","message":"ini_set(): $
{"reqId":"nB4ZFHJ1OOZVcFh0fO8Z","level":3,"time":"2018-07-31T23:38:37+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"DELETE","url":"\/remote.php\/webdav\/Photos\/Squirrel.jpg","message":"ini_set(): A sessi$
{"reqId":"1yb1EyYm4uKCnPLm0Z9S","level":3,"time":"2018-07-31T23:38:38+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/index.php\/apps\/files\/ajax\/getstoragestats.php?dir=%2FPhotos","message"$
{"reqId":"1SdhaEU06EDrppLLQlAB","level":3,"time":"2018-07-31T23:38:55+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/ocs\/v2.php\/apps\/notifications\/api\/v1\/notifications?format=json","mes$
{"reqId":"M4yUzvRRdV3m9MUKg88c","level":3,"time":"2018-07-31T23:39:00+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"PUT","url":"\/remote.php\/webdav\/Photos\/DSC_1041-Edit-Edit.jpg","message":"ini_set(): $
{"reqId":"WYGPIx4HBIWlftCp1Fk1","level":3,"time":"2018-07-31T23:39:00+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"MKCOL","url":"\/remote.php\/dav\/uploads\/REMOVED SENSITVE DATA\/web-file-upload-5d0029cb2f60e1fc52c78126$
{"reqId":"b38d5eRK5dstyQm4uSum","level":3,"time":"2018-07-31T23:39:01+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"MKCOL","url":"\/remote.php\/dav\/uploads\/REMOVED SENSITVE DATA\/web-file-upload-b1299563657b5a13ce58ebae$
{"reqId":"Fcpf23llfawtMRdJjYOK","level":3,"time":"2018-07-31T23:39:01+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"MKCOL","url":"\/remote.php\/dav\/uploads\/REMOVED SENSITVE DATA\/web-file-upload-2278c06e0638e3b8900e16a4$
{"reqId":"whV8vCc6AhosKNb4vh7z","level":3,"time":"2018-07-31T23:39:01+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"MKCOL","url":"\/remote.php\/dav\/uploads\/REMOVED SENSITVE DATA\/web-file-upload-3475abcca0584b23bf015c99$
{"reqId":"zncuGNYgO3SLq1os66aE","level":3,"time":"2018-07-31T23:39:01+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"MKCOL","url":"\/remote.php\/dav\/uploads\/REMOVED SENSITVE DATA\/web-file-upload-c6df1b291c473fc44330b0c5$
{"reqId":"SDcenMMu1h1qzxfoZiyR","level":3,"time":"2018-07-31T23:39:02+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"PUT","url":"\/remote.php\/webdav\/Photos\/DSC_1041-Edit-Edit-2.jpg","message":"ini_set()$
{"reqId":"DKyktNMeaobrEKFu3GLD","level":3,"time":"2018-07-31T23:39:02+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"PROPFIND","url":"\/remote.php\/webdav\/Photos\/DSC_1041-Edit-Edit.jpg","message":"ini_se$
{"reqId":"qiJ0U5yeAMeJlMvtSazT","level":3,"time":"2018-07-31T23:39:03+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/remote.php\/dav\/files\/REMOVED SENSITVE DATA\/Photos\/DSC_1041-Edit-Edit.jpg?c=441c5a84b7f$
{"reqId":"pl2Fz2bh3XWdt3uV2UlP","level":3,"time":"2018-07-31T23:39:04+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"PROPFIND","url":"\/remote.php\/webdav\/Photos\/DSC_1041-Edit-Edit-2.jpg","message":"ini_$
{"reqId":"knTk3bZuRr2W5pM8kRtu","level":3,"time":"2018-07-31T23:39:04+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"PUT","url":"\/remote.php\/webdav\/Photos\/DSC_1049-Edit.jpg","message":"ini_set(): A ses$
{"reqId":"PPNME7Vp6DIjfR7XiYD3","level":3,"time":"2018-07-31T23:39:04+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/remote.php\/dav\/files\/REMOVED SENSITVE DATA\/Photos\/DSC_1041-Edit-Edit-2.jpg?c=1573cb0d0$
{"reqId":"x6JubM4v3F8bDKkReCpO","level":3,"time":"2018-07-31T23:39:06+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"PROPFIND","url":"\/remote.php\/webdav\/Photos\/DSC_1049-Edit.jpg","message":"ini_set(): $
{"reqId":"Q3tbXwBgMQcRW5C7Jrwy","level":3,"time":"2018-07-31T23:39:06+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"PUT","url":"\/remote.php\/webdav\/Photos\/DSC_1065-Edit.jpg","message":"ini_set(): A ses$
{"reqId":"f0XGd3nupMfqg0v6zAne","level":3,"time":"2018-07-31T23:39:06+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/remote.php\/dav\/files\/REMOVED SENSITVE DATA\/Photos\/DSC_1049-Edit.jpg?c=785056dcfbadd057$
{"reqId":"wRGYXu40nmEMeUncE2NC","level":3,"time":"2018-07-31T23:39:07+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"PROPFIND","url":"\/remote.php\/webdav\/Photos\/DSC_1065-Edit.jpg","message":"ini_set(): $
{"reqId":"wuyx5BhkOzGt4tYVKvls","level":3,"time":"2018-07-31T23:39:07+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"PUT","url":"\/remote.php\/webdav\/Photos\/DSC_1065-Edit-Edit.jpg","message":"ini_set(): $
{"reqId":"5aTXgOtTWcqhTnWZio87","level":3,"time":"2018-07-31T23:39:07+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/remote.php\/dav\/files\/REMOVED SENSITVE DATA\/Photos\/DSC_1065-Edit.jpg?c=f649e961fb033d85$
{"reqId":"tkmS8MtbMOJMVZ9qmzoZ","level":3,"time":"2018-07-31T23:39:09+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"PUT","url":"\/remote.php\/webdav\/Photos\/DSC_1099-Edit.jpg","message":"ini_set(): A ses$
{"reqId":"YRKkCHlEYxwI7Yuo1LLS","level":3,"time":"2018-07-31T23:39:09+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"PROPFIND","url":"\/remote.php\/webdav\/Photos\/DSC_1065-Edit-Edit.jpg","message":"ini_se$
{"reqId":"IC4JtKRwflQyYIraTXIG","level":3,"time":"2018-07-31T23:39:10+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/remote.php\/dav\/files\/REMOVED SENSITVE DATA\/Photos\/DSC_1065-Edit-Edit.jpg?c=d42520ed6b5$
{"reqId":"u6yVgdDH8V9KYxlkpgSb","level":3,"time":"2018-07-31T23:39:11+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"PROPFIND","url":"\/remote.php\/webdav\/Photos\/DSC_1099-Edit.jpg","message":"ini_set(): $
{"reqId":"zQv0cxIY13MLQ8mfgnau","level":3,"time":"2018-07-31T23:39:11+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"PUT","url":"\/remote.php\/webdav\/Photos\/DSC_1099-Edit-2.jpg","message":"ini_set(): A s$
{"reqId":"xRCwB4PPqjUznwbZEJDC","level":3,"time":"2018-07-31T23:39:11+00:00","remoteAddr":"REMOVED SENSITVE DATA","user":"--","app":"PHP","method":"GET","url":"\/remote.php\/dav\/files\/REMOVED SENSITVE DATA\/Photos\/DSC_1099-Edit.jpg?c=b52846bf4f8c0290$
