hola, es la primera vez en este foro y tenia un problema despues de instalar owncloud sobre debian 9 y no se que hacer, gracias de antemano
The PHP zip module is not installed.
Consult your server administrator to install the module.
The PHP dom module is not installed.
The PHP XMLWriter module is not installed.
The PHP XMLReader module is not installed.
The PHP libxml module is not installed.
The PHP mb multibyte module is not installed.
The PHP GD module is not installed.
The PHP SimpleXML module is not installed.
The PHP modules have been installed, but they are listed as if they were missing
Check with your server administrator to restart the web server.
