Help a beginner
When I try to access owncloud trough my ip this happens.
Already tried to add to trusted domains too.
your logfiles should tell you your problem:
how do i see the logfile?
Did you had a look at the link above? This is telling you everything you need and how to see the logfile.
ah ok ty and sorry…
If you don’t see an issue in your logfiles on your own feel free to post these in here. Then a more experienced user could have a look at it.
I have fixed it but now I have this message.
Already did this
-wget -nv download.owncloud.com -O Release.key
-apt-key add - < Release.key
-sh -c ā€œecho ā€˜deb download.owncloud.com /’ > /etc/apt/sources.list.d/owncloud.listā€
-apt-get update
-apt-get install owncloud-files
Please create a new thread for this new issue and translate the message in English. Thanks.
